Author Topic: Cherry Stabilizers?  (Read 2121 times)
Offline awhitedev
Cherry Stabilizers?
« on: Sat, 11 April 2015, 11:34:11 »
Is it just me or does it seems like Cherry Stabilizers are nearly impossible to get in the US? I've only been able to get stabilizers as part of a kit in a GB. Does anyone know where I can order some?
Offline Flyersfan1
  • Hi!
Re: Cherry Stabilizers?
« Reply #1 on: Sat, 11 April 2015, 11:37:50 »
Gon and Winkeyless have some on their respective sites, but the shipping is a real killer to the US, your best bet would be the classifieds until some retailer based in the US can hopefully stock some.
Quote from: Photekq
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Sat, 11 April 2015, 11:42:50 »
Best bet is to start googling Cherry's part numbers.  Took me a while but last time I was looking I bought 15 2 unit cherry pcb mount stabs
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 11 April 2015, 15:09:08 »
Depending on what you are looking for specifically, I do have some on hand now. Otherwise, I'll be offering them again in my next GMK buy which will be starting really soon.
« Last Edit: Sat, 11 April 2015, 15:10:41 by IvanIvanovich »
Offline cmadrid
« Reply #4 on: Sat, 11 April 2015, 15:27:36 »
I foolishly forgot to order some PCB mount stabs this time around, only got some plate mount.. will have to jump in on some pcb mount next go round
Offline FreeCopy
« Reply #5 on: Sat, 11 April 2015, 15:48:59 »
I did the same thing myself. Would have liked to make substantially more heavy handed orders on both plate and PCB mount.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline cmadrid
« Reply #6 on: Sat, 11 April 2015, 16:10:22 »
My wife was grumpy enough that I bought the ones I did (and the pcb) with no clear plans on what I was going to use them on, lol
Offline awhitedev
« Reply #7 on: Sat, 11 April 2015, 17:13:06 »
Thanks Ivan :) PM sent. Let me know if you didnt get it. I think my network has been having issues recently.
