Author Topic: Keycap Fun Times  (Read 6150 times)
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Keycap Fun Times
« on: Sun, 12 April 2015, 01:59:41 »
I've been kicking this idea around since I first got here, but lots of people have been making amazing stuff...
Soooooo I didn't think I could make anything I'd be happy with.
Well I got some ideas and figured it was time to see what I could do.
Here is my start!!!
I don't like the cat at all... It looks like crap, but I figure I can get it whipped into shape soon.
Re: Keycap Fun Times
« Reply #1 on: Sun, 12 April 2015, 02:06:07 »
They look really great, especially the shark :)
What's the underneath like?
  • Kitteh Overlord
  • Say WHAAT...
« Reply #2 on: Sun, 12 April 2015, 02:08:01 »
Just a stock dsa cap
but I would like to bulk them up if I make a cast.
THIN IS NO GOOD!!!
« Reply #3 on: Sun, 12 April 2015, 02:08:55 »
THIN IS NO GOOD!!!
True - many artisan keycaps do seem to be thicker than the average OEM keycap.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #4 on: Sun, 12 April 2015, 03:46:10 »
a chubby jason vorhees!!!
« Reply #5 on: Sun, 12 April 2015, 08:41:25 »
The shark is awesome! My son would go nuts to get that on his gaming board.
If you are affixing them to existing caps, you should be able to do buckling springs, right?
- D Trump 2026-10-24
  • Kitteh Overlord
  • Say WHAAT...
« Reply #6 on: Sun, 12 April 2015, 10:15:37 »
Yeah, It might be a while befofre I get around to making molds... I'll let you know when I get one done!
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #7 on: Mon, 13 April 2015, 02:59:32 »
Here is my start!!!
So from the looks of it you used super sculpey? And if those are PBT DSA caps you used as the base, then you can cook the sculpey at a lower heat (just north of 200 degrees works very well for this size). That makes the mold making process a bit easier because you don't have to worry about deformation.
Apart from that I would try to smooth out the cats glasses a bit to sit closer to the face, otherwise the silicone that would be between the two pieces will eventually tear out when you try to demold it.
They are great looking caps, and I wish you the best of luck in the crazy world of casting!
Offline byker
  • Literally Canada
« Reply #8 on: Mon, 13 April 2015, 03:13:48 »
Nice start into cap making AM! Excited to see how you progress and what designs you come up with!  :)
« Reply #9 on: Mon, 13 April 2015, 04:59:20 »
That Jason is wicked !!
Offline derezzed
« Reply #10 on: Mon, 13 April 2015, 21:13:05 »
I like the profile you chose for the shark's face.  The cat amuses me.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #11 on: Mon, 13 April 2015, 21:15:23 »
What did you use to model these?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12 on: Tue, 14 April 2015, 04:12:39 »
How has Halverson not responded here about that shark cap?
GON NerD TKL DTA Edition
« Reply #13 on: Tue, 14 April 2015, 05:46:49 »
Already posted in the Church thread.
Offline domoaligato
« Reply #14 on: Tue, 14 April 2015, 14:07:36 »
These are great! Have you tried any casting yet?
Offline tigersharkdude
« Reply #15 on: Wed, 15 April 2015, 07:28:33 »
Take my money
  • Kitteh Overlord
  • Say WHAAT...
« Reply #16 on: Fri, 17 April 2015, 04:21:54 »
lol, sorry dudes... I haven't been keeping up with this!!!
I'm looking at casting stuff now and I'm gonna pester nubs and domo about it... hopefully get it right the first ttime!!!
I'm still not sure about the resin I should use... but again I'm sure someone will help me out...
If all goes well, I should be able to get started on casting this week!!!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #17 on: Fri, 17 April 2015, 04:23:46 »
Wha... it's just a DSA ABS key with clay on it...
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #18 on: Fri, 17 April 2015, 05:25:46 »
I wasn't sure what kind of medium you used for modeling it, the keycap was obvious
  • Kitteh Overlord
  • Say WHAAT...
« Reply #19 on: Fri, 17 April 2015, 05:40:59 »
lol I'm dumb... the cat was me trying to make my avatar. the rest of them are just from ideas of things I wanted as keycaps!!!
Offline Eziak
« Reply #20 on: Fri, 17 April 2015, 08:57:07 »
I love sharks... please make that. I want one so badly.
Boards:
CM Storm Novatouch
« Reply #21 on: Sat, 18 April 2015, 15:31:35 »
I'm digging the Shark, Cat, and Jason
