Author Topic: clicky space invader battleship, $40+shipping OBO  (Read 2038 times)
Offline jacobolus
« on: Sun, 12 April 2015, 22:27:47 »
Kinda dirty, supposedly has some sticky switches, and there’s some silly writing in sharpie on the back, but someone might still want it.
http://www.ebay.com/itm/291431319693
« Last Edit: Sun, 12 April 2015, 22:30:10 by jacobolus »
Re: clicky space invader battleship, $40+shipping OBO
« Reply #1 on: Mon, 13 April 2015, 06:58:28 »
That doesn't look too bad, just surface dirt.
I had one of those that I bought for parts but it was just so nice (including native PS/2 with no drama) that I sold it on to somebody who really wanted it intact. Was that you, Jacobolus, or maybe rjrich?
- D Trump 2026-10-24
Offline engicoder
« Reply #2 on: Thu, 16 April 2015, 15:21:59 »
I picked this up, unfortunately, the seller wrapped in a couple layers of 3/16 bubble wrap and threw it in a USPS large flat rate box with no other packing. As a result, it now has 2 broken key caps and a 1 inch crack in the lower left corner of the case.  :mad:
This is the third keyboard I have received loose in a USPS large flat rate box. Got lucky of the first two. Why are so many sellers so cheap on packing?
« Last Edit: Thu, 16 April 2015, 15:41:50 by engicoder »
« Reply #3 on: Thu, 16 April 2015, 16:04:20 »
I have a Hi-Tek parts board with about 1/2 to 2/3 of its keys.
Tell me what you need, if they are common standard 1x I may be able to help you.
Also have spare switches but they are nasty to work with because they have 4 very thin wire "legs" and no strain relief at all.
Offline engicoder
« Reply #4 on: Thu, 16 April 2015, 16:17:53 »
Turns out dirty, it was. Smells of diesel, so I suspect it spent its life inside some type of repair shop. Here a few quick photos:
97511-0
97513-197515-2
97517-397519-4
97521-597523-697525-7
There is a small door in the rear of the case. The PCB has the footprint for what looks like could have been a set of dip switches, which is missing.
« Last Edit: Thu, 16 April 2015, 16:31:41 by engicoder »
Offline engicoder
« Reply #5 on: Thu, 16 April 2015, 16:21:38 »
Broken caps were
1. Center stepped caps lock with lock symbol
2. Left alt
