Author Topic: Costar Stabalized Spacebar- Right Side Rattling  (Read 2998 times)
Offline Seriously
  • Filco forever
« on: Mon, 13 April 2015, 00:22:08 »
Hey folks,
Just got a board in and fixed her up, only thing odd about it is that the right side of the spacebar rattles. This is on a Filco Majestouch 2 with MX Blacks, though my Majestouch 1 doesn't exhibit any of the same issues. Both boards don't have any lubricant applied to the stabilizers or inserts.
Anything else I can do? Curious to see if I can replace the Costar stabilizers with Cherry ones, is that possible?
WASD CODE 104 - Filco Majestouch 2 - Filco Majestouch - Filco Majestouch 2 - Realforce 87UW 45G
Reserves: Filco Minila - KBtalking Pure Pro
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Costar Stabalized Spacebar- Right Side Rattling
« Reply #1 on: Mon, 13 April 2015, 01:16:50 »
I would just try a bit of plastic safe grease.  As far as swapping the stabs out for Cherry, that would work unless you swap the plate, or the pcb to one with PCB mount stab support and open up the holes.
Offline strict
  • TKL Zealot
« Reply #2 on: Mon, 13 April 2015, 08:07:41 »
Costar stabs can be noisy if they don't have a nice, thick lube on them. I have been using Krytox thick or Extra Thick on my Costar stabs and they are dead silent.
