Author Topic: Phone Keyboard Adapter  (Read 4851 times)
Offline Bludude4
« on: Mon, 13 April 2015, 21:11:34 »
Searching for the original thread would be like searching for a needle in a haystack, so I created this thread. I can put it in a text file and you can delete the thread once someone's responded or something, but what's the name of the adapter that you plug into the micro-USB port on your phone and it makes any physical keyboard work with Android?
All hail Hall Effect keyboards!
I'm a QFR Blues noob.
WASD keycaps are terrible.
Re: Phone Keyboard Adapter
« Reply #1 on: Mon, 13 April 2015, 22:39:26 »
It's called an OTG (on-the-go) cable. :)
Offline Bludude4
« Reply #2 on: Mon, 13 April 2015, 22:58:05 »
I don't know what the world would do without you, JDCarpe.
Offline alexofthewest
« Reply #3 on: Thu, 16 April 2015, 19:04:30 »
I have a related question to this. What are the ends that you need called. To connect a poker 2 to android phone it is micro b male to mini b male correct or is it something else?
Offline strafe
    • Strafe's Blog
« Reply #4 on: Thu, 16 April 2015, 19:41:09 »
I guess that would work fine.  You could also get a USB micro male to USB female, and plug in your existing cable into it.
Freebird WKL (Blacks Clear-Tops), iKBC F-104 (Blacks) and more!
Offline Bludude4
« Reply #5 on: Thu, 16 April 2015, 23:12:08 »
So where can I get an OTG cable? I have an Android phone and a QFR, if that effects the answer.
Offline Baron Von Clop
« Reply #6 on: Thu, 16 April 2015, 23:53:09 »
They're on Amazon for like four dollars + prime, that's where I got mine.
Offline FreeCopy
« Reply #7 on: Fri, 17 April 2015, 00:00:46 »
I got my adapter from monoprice, item# 11193. Been good so far on Android with PokerII.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline Hzza
« Reply #8 on: Fri, 17 April 2015, 05:14:25 »
I use one of these when I need to do something with a keyboard on my phone or tablet.
Offline Oobly
« Reply #9 on: Tue, 21 April 2015, 01:40:00 »
Pexon makes some beautiful ones.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
