Author Topic: Cherry g81-3097lqnde & Cherry G81-3000lgnde  (Read 7622 times)
Offline RackaBT
Offline bazh
Re: Cherry g81-3097lqnde & Cherry G81-3000lgnde
« Reply #1 on: Tue, 14 April 2015, 10:33:58 »
not to disappointed you but G81s with lasered caps are hardly got attentions here :D but GLWS anyway  :thumb:
HHKB Pro2 white
Newbie again
Offline Nover
« Reply #2 on: Tue, 14 April 2015, 10:44:37 »
Way overpriced, both of them. 2nd one at least has thick keycaps, but they aren't hard to come by at all. And you can usually grab them for < 10€ shipped.
SSK, Ducky YOTD
Offline RackaBT
« Reply #3 on: Tue, 14 April 2015, 10:56:58 »
Overpriced? Ok, well.....will change the buy by now price.
another question.  I will list another cherry keyboard. Its a G83-13800LAADE/00. how much is this item worth?
Offline FrostyToast
  • Litshoard
« Reply #4 on: Tue, 14 April 2015, 11:00:13 »
The first letter in the model number will tell you the material that the caps use and the printing. L should refer to laser printed caps which are the least valuable. H would tell you it's doubleshot abs which is slightly more valuable. S would tell you it's PBT dyesubs which are the most valuable.
Quote from: elton5354
Offline RackaBT
« Reply #5 on: Tue, 14 April 2015, 11:07:08 »
Thanks Frosty, that are useful informations.
Offline bazh
« Reply #6 on: Tue, 14 April 2015, 11:24:04 »
plus you should read the number after G also, G83 means that it use ML switch, which less interested than G80 (MX) and G81 (MY, but keycaps is MX-compatible), and there's also the G84 rubberdome with awesome dyesub caps but worth nothing
HHKB Pro2 white
Newbie again
Offline Nover
« Reply #7 on: Tue, 14 April 2015, 11:25:38 »
Other way around, G84 are ML, G83 are rubberdomes from hell.
SSK, Ducky YOTD
Offline bazh
« Reply #8 on: Tue, 14 April 2015, 11:27:47 »
oh yeah, messed up **** :(
HHKB Pro2 white
Newbie again
Offline lolpes
« Reply #9 on: Tue, 14 April 2015, 16:30:00 »
ok, so how much are the dye subs from a g81 valued at? because i have 2 sets of those, and i am wanting to sell one of them
