Author Topic: Wood wrist rest!  (Read 4900 times)
Offline Eziak
Wood wrist rest!
« on: Thu, 16 April 2015, 08:33:12 »
So I'm getting ready to make a wood wrist rest out of Walnut and Maple wood. Something custom fit for my Novatouch. I was wondering what other people have used as a finish on their wooden wrist rests? I'm currently leaning towards Arm-R-Seal from General Finishes as it's a pretty easy wipe on varnish. Any suggestions or tips would be greatly appreciated.
Boards:
CM Storm Novatouch
Re: Wood wrist rest!
« Reply #1 on: Thu, 16 April 2015, 09:08:27 »
I prefer an oil finish and or wax finish.  Arm-R-Seal is fantastic, one of my favorites, but PU can make your palms all sweaty when you rest them on it.
Offline tigersharkdude
« Reply #2 on: Thu, 16 April 2015, 09:11:52 »
I used a Min wax stain and polyurethane,  then wetsanded and buffed for a shine
« Reply #3 on: Thu, 16 April 2015, 09:19:53 »
I still don't care as much for PU for something you rest your palms on since it can make you sweat.  I've used PU (Arm-R-Seal), wax paste, Danish oil, and so on, and oils and waxes end up feeling the best.  A buffed oil and wax finish will give you a shine too if you want it, but PU is the easiest to maintain.
Offline Eziak
« Reply #4 on: Thu, 16 April 2015, 18:30:58 »
By an oil finish are you talking just straight boiled linseed oil, or an oil based varnish? I thought straight oil wouldn't be protective enough since the wrist rest would be getting pretty constant skin contact. Arm-r-seal is oil based, though.
Boards:
CM Storm Novatouch
« Reply #5 on: Thu, 16 April 2015, 18:36:12 »
Something like BLO, a true Danish oil, Ting oil, and so on.  If you key polymerize properly, it will be durable.
Arm-r-Deal is wipe on PU.  I have it and use it, it's nice, but the PU finish can make you sweat.
Offline Eziak
« Reply #6 on: Thu, 16 April 2015, 18:41:31 »
Okay, I've never really used just straight oil as a finish before. My desk that I made I have arm-r-seal on and it doesn't really make me sweat so I might stick with that. But do you have any durability issues with BLO or danish oil?
Boards:
CM Storm Novatouch
« Reply #7 on: Thu, 16 April 2015, 21:05:55 »
BLO polymerizes in the wood and will not be affected.  Danish oil, if with actual Tung oil not the garbage most sell, will polymerize and have a varnish that you can wear through, but the oil will not be affected..
Offline Eziak
« Reply #8 on: Sat, 25 April 2015, 18:53:52 »
http://imgur.com/gallery/jI0nY/new
I just finished my project, I did end up using Arm-r-seal on it as I didn't feel that BLO or something like that would be protective enough, but we shall see. I think it turned out pretty well.
Boards:
CM Storm Novatouch
« Reply #9 on: Mon, 27 April 2015, 15:36:24 »
loving the two tone, did you use different woods, or did you mask the stripes on?
Offline Eziak
« Reply #10 on: Mon, 27 April 2015, 16:55:51 »
The darker strips are walnut and the lighter strips are maple all glued together.
Boards:
CM Storm Novatouch
