Author Topic: Geekkeys keysets?  (Read 3055 times)
Offline Keytrun
Geekkeys keysets?
« on: Fri, 17 April 2015, 00:34:08 »
http://www.geekkeys.com/keysets/
Does anyone know if these are any good? Well made? I have a set of IMSTO thick PBT. Are these the same thing?
The enlarged pictures look like you can see the stem through the top. Is that the case?
What is this otaku thing? http://www.originativeco.com/collections/keysets/products/black-otaku ? Are those the exact same keycaps as the black pbt thick caps on geekkeys? Is there a better place to get some good thick pbt sets?
« Last Edit: Fri, 17 April 2015, 00:44:04 by Keytrun »
Offline KnivesM
Re: Geekkeys keysets?
« Reply #1 on: Fri, 17 April 2015, 00:45:50 »
Depends on which one your talking about. The Thick Blank/Printed ones like these as nice and thick but have a kind of rough texture to them and are blank or lasered where IMSO is dyesub. The dyesub set is only 1.00mm thick and IIRC IMSTO uses Vortex or BSP for his caps which are ~1.5mm/1.3mm thick, so your IMSTO set should be thicker if I'm right. Also they are OEM profile where IMSTO is cherry.
Otaku = blank, I don't think they are the same as the ones on Geekkeys.
« Last Edit: Fri, 17 April 2015, 00:51:05 by KnivesM »
Others
Offline Keytrun
« Reply #2 on: Fri, 17 April 2015, 00:53:32 »
I'm referring to these: http://www.geekkeys.com/geekkeys-blue-grey-blank-thick-pbt-108-keyset/
You can see the stems / scratches  in the picture.
Offline KnivesM
« Reply #3 on: Fri, 17 April 2015, 01:00:41 »
Any of his that say Thick PBT are the same keys as the one I linked I'm pretty sure, they are just dyed different colors.
Others
« Reply #4 on: Fri, 17 April 2015, 02:13:48 »
Vendor forum here.
Offline Keytrun
« Reply #5 on: Fri, 17 April 2015, 04:09:14 »
Could someone move this to that section maybe?
