Author Topic: NCIX USA Weekly Special: Topre Typeheaven $119.99  (Read 3289 times)
Offline dante
« on: Sat, 18 April 2015, 19:13:40 »
Offline Sygaldry
  • Edema Ruh
Re: NCIX USA Weekly Special: Topre Typeheaven $119.99
« Reply #1 on: Sat, 18 April 2015, 19:17:45 »
If I were in the market for a full sized keyboard. This would be it.
Great price for a great keyboard (probably my favorite full sized keyboard other than the Model M)
null
Offline platypus
  • dongerino adventures
« Reply #2 on: Sat, 18 April 2015, 19:43:10 »
Buying a thorpe is already a mistake, but a thorpe with subpar stock caps?
Offline intelli78
« Reply #3 on: Sat, 18 April 2015, 19:44:46 »
Thank you for your input.
Offline Sygaldry
  • Edema Ruh
« Reply #4 on: Sat, 18 April 2015, 20:24:54 »
Nice try.
Those "sub par" caps are still better than the excrement included with stock MX boards (apart from Cherry Corporation boards).
null
Offline platypus
« Reply #5 on: Sat, 18 April 2015, 20:35:43 »
Nice try.
I don't think you should use those either, but at least you can find a decent replacement set fairly easily for MX boards.
Offline Sygaldry
  • Edema Ruh
« Reply #6 on: Sat, 18 April 2015, 20:39:34 »
Nice try.
Decent replacement MX caps cost the same as Topre caps. Your argument is moot.
null
Offline platypus
« Reply #7 on: Sat, 18 April 2015, 20:46:14 »
http://www.ebay.com/itm/281664522419
Link me a comparable 40$ topre set and I'll agree with you.
Offline heedpantsnow
  • Old enough to know better
« Reply #8 on: Sat, 18 April 2015, 20:54:42 »
Lol well played.
I'm back.
Offline Sygaldry
  • Edema Ruh
« Reply #9 on: Sat, 18 April 2015, 21:03:08 »
Comparable keycaps? Try free. The Type Heaven stock key caps are actually quite nice.
« Last Edit: Sat, 18 April 2015, 21:11:50 by Sygaldry »
null
Offline platypus
« Reply #10 on: Sat, 18 April 2015, 21:11:06 »
How would you justify buying this over a realforce then?
Unless you use the ****ty stock caps you're going to shell out over a hundred for decent replacements, when you could have just bought something with decent caps to begin with.
Offline Sygaldry
  • Edema Ruh
« Reply #11 on: Sat, 18 April 2015, 21:13:52 »
Because for 100 dollars less I can get the same typing feel with only slightly inferior keycaps?
Your whole argument hinges on the premise that you HAVE to replace the Type Heaven keycaps, and this is just not the case.
null
Offline dante
« Reply #12 on: Sat, 18 April 2015, 21:13:55 »
Having owned a Topre TypeHeaven I can say the keycaps are just fine.
The deal is only good through tomorrow only so I'm locking the thread so others won't use it as an outlet for their menstrual cycle.
