Author Topic: Please recommend an nVidia video card  (Read 8790 times)
Offline ironcoder
« on: Fri, 11 September 2009, 09:42:11 »
Hi guys,
Seeing as how there is a high level of geekness on the board, I was hoping some of you guys could suggest which video card I should get.
I want a reasonable card so I can run dual head (2 DVI outputs). I don't game or use CAD so I don't need a high-end card, I just need something that will drive dual 22 inch LCDs to their rated 1680x1050 without breaking a sweat. 95% of the use is reading doc and coding so I need a crisp image. I have two other boxes on MSI motherboards with onboard nVidia chipsets (nForce 7100/630i) and I am sold on nVidia from what I have seen so far. Their stuff is great and the drivers install painlessly and work on Linux and Solaris.
The box in question is an E8400 on MSI G31 motherboard (please don't ask, it was the best I could do!) with Intel's G31/33 chipset. el cheapo 450W EZCool power supply (no SLI for me!). Not sure what else to add.
I can find Zotac and Gigabyte locally, right now the shop I use has a good selection of Gigabyte, not sure how good they are. I have a PCIe slot on this mobo.
Thanks.
« Last Edit: Fri, 11 September 2009, 09:45:42 by ironcoder »
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline ch_123
« Reply #1 on: Fri, 11 September 2009, 09:51:35 »
If all you want is to drive two monitors without doing any intensive 3D work, I'd get one of the basic ones like the 9400GT or 9500GT. However, you'd probably have better luck finding a 9500GT that has two DVIs.
Offline huha
« Reply #2 on: Fri, 11 September 2009, 09:56:55 »
I'd strongly recommend on getting a passively cooled version (i.e. without fan). Basically, you can get as cheap as it gets if you don't do CAD, gaming or gpu-accelerated computing. But do insist on passive cooling.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline erricrice
« Reply #3 on: Fri, 11 September 2009, 10:04:35 »
+1 to those
Anything you get will be fine as long as you're not doing 3d stuff.  Just ask beforehand if it has two DVIs.  There are many versions of the lower end cards, some with HDMI, some with vga(all will have 1 DVI port, but the second is up for grabs) so make sure of what you're getting before you pay for it.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline cmr
« Reply #4 on: Fri, 11 September 2009, 12:59:16 »
you can't go wrong with EVGA. just make sure you have enough PSU to power it up and you should be all set. i've had four EVGA cards in the past 6-7 years and every one has worked up until the day i replaced it with something faster. my 7600gs even survived a power surge that killed practically everything in my apartment... although the lightning did take out its DVI port, the VGA port continued to work until i retired it in favor of a 9800gt.
i've had less pleasant results with other manufacturers.
Offline erricrice
« Reply #5 on: Fri, 11 September 2009, 13:44:52 »
Quote from: cmr;117020
Yes, EVGA is the #1 when it comes to nvidia cards.  You usually pay a little premium for it, but it is not usually much and when you weigh it against the fact that it will most likely NEVER fail, then it's totally worth it.  Plus with the lower end cards there usually isn't a price difference.
Logitech G5[/FONT]
Offline timw4mail
    • https://timshomepage.net
« Reply #6 on: Fri, 11 September 2009, 14:00:22 »
I've never had troubles with ATi's drivers in Linux...
From what you described, you might as well just buy the cheapest card you can find.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline cmr
« Reply #7 on: Fri, 11 September 2009, 14:29:53 »
ATI's linux drivers are absolutely atrocious. they barely work at all.
Offline timw4mail
« Reply #8 on: Fri, 11 September 2009, 14:38:47 »
Quote from: cmr;117047
I've not had that kind of issues with ATI's drivers, especially considering that I have a 4870, latest generation card. Stop perpetuating a myth.
And to be honest, Nvidia's driver installer is a pain, especially if you try to install the self-installing driver in Ubuntu.
At any rate, from what I understand of the original poster's needs, just about any low-end video card will do.
Offline ch_123
« Reply #9 on: Fri, 11 September 2009, 14:55:03 »
Quote from: timw4mail;117048
Sometimes when there's a problem with something, it doesn't affect everyone. I know more than one person who has had problems with recent ATI cards and recent ATI drivers (and these are the kind of people who have  scary amounts of experience and knowledge about Linux) so whether you like or not, there is an issue, and you're safer with nVidia for Linux.
What problems did you have in particular?
Offline cmr
« Reply #10 on: Fri, 11 September 2009, 15:40:29 »
for several years i have tracked ATI's driver on a wide variety of cards dell ships to us at work. dual displays? disaster. 3d acceleration? disaster. play a low-resolution video without insane flickering? disaster. x crashes all the time. weird color artifacts. don't you dare switch to a VT and switch back to x.
my most recent run-in with fglrx was mindblowing. we had two boxes with identical hardware. we put an identical OS installation on both. on one box the fglrx driver worked at its usual level of half-assed performance and frustrating instability. on the other one it panicked the kernel every time.
the linux fglrx driver is junk. full stop.
Offline timw4mail
« Reply #11 on: Fri, 11 September 2009, 21:52:18 »
Quote from: cmr;117074
No, you miss the key point there.
In all seriousness, I'd buy from S3 before Nvidia.
Offline ch_123
« Reply #12 on: Sat, 12 September 2009, 02:53:38 »
Quote from: timw4mail;117171
Which is?
nVidia definitely aren't perfect, but at the moment, they're the lesser of two evils when it comes to getting a g-card up and running under Linux. I've had very few problems so far.
Offline ironcoder
« Reply #13 on: Sat, 12 September 2009, 11:50:05 »
Thanks guys. Couple of questions.
Why passive cooling? It gets pretty hot here half the year so I like all the cooling I can get.
I don't know if I can find the EVGA brand locally, I'll look for it. The store I use used to have a good selection of Zotac now they are down to one Zotac and all the rest Gigabyte. Are the Gigabytes any good?
They also have a couple of new brands I never heard of, Gainward and Sparkle. Anybody know anything about those? We usually get the el cheapo stuff here so I always ask before I get taken to the cleaners.
As far as nVidia vs. anything else, like I said nVidia is my choice, their drivers installed and worked flawlessly on 2 Linux boxes and a Solaris box. I think that's pretty impressive.
« Last Edit: Sat, 12 September 2009, 11:54:57 by ironcoder »
Offline Hak Foo
  • Make America Clicky Again!
« Reply #14 on: Sat, 12 September 2009, 13:59:08 »
I've got passively cooled HD3650 (Arctic Cooling Accelero S2) in Arizona.  The card hits 50C under video-decoding load (primary use) in ambient 25.
The stock cooler idled at like 50C and had fan noise + a fan to fail.
Overton130, Box Pale Blues.
Offline Mr.6502
« Reply #15 on: Sat, 12 September 2009, 14:02:43 »
I've put cheap-o Sparkle cards in a couple computers for co-workers.  I believe they were GeForce 7200s for about $30 a piece.  They held up fine but thats a pretty small sample.  They were both used in two monitors setups but they didn't have dual DVI.  They were DE-15 + DVI + S-Video.
I would agree that EVGA is what to look for.  I've used Sapphire for ATI based cards recently as well.  I have a 4870 from them that is very quiet and still stays cool.  But it would be overkill for what you're looking for.
"Engineers are really good at labeling and branding things ...  If we had named Kentucky Fried Chicken, it would have been Hot Dead Birds."
-Vint Cerf
Offline ironcoder
« Reply #16 on: Sat, 12 September 2009, 14:48:29 »
Thanks, afaik there are no EVGA cards around here. I'll have to check more but my normal places don't have any
Offline erricrice
« Reply #17 on: Sat, 12 September 2009, 16:40:59 »
Quote from: ironcoder;117297
Gigabyte is the best of the manufacturers that you mentioned.  Zotac would be the next one down then Gainward and then Sparkle.  Really Gigabyte is the only 'good' manufacturer of the bunch.  The rest of them haven't been around as long or really haven't proven their reliability.
Logitech G5[/FONT]
Offline ironcoder
« Reply #18 on: Sun, 13 September 2009, 02:17:46 »
Thanks. I was wondering because the nVidia site is linking to Zotac boards big time. I was wondering if they were a preferred partner of some kind. (yeah, probably the money making kind!)
They have plenty of Gigabytes, I'll go over the selections again. I may have to go to a 9800 to get dual DVI though.
Offline ch_123
« Reply #19 on: Sun, 13 September 2009, 03:42:12 »
My 9600GT has two DVIs (along with HDMI and DP) and I'm pretty sure I've seen 9500GTs with dual DVI out. If you find one with HDMI, that's just as good as HDMI is electrically compatible with DVI, so all you need is a simple adapter cable.
Offline ironcoder
« Reply #20 on: Sun, 13 September 2009, 04:09:31 »
Thanks for the info. The problem for me is also cables. I haven't found any extension cables locally. I'm going to rearrange my office, in a few weeks I'll know how long the runs are going to be and then I can start converting to dual head.
Offline ch_123
« Reply #21 on: Sun, 13 September 2009, 04:50:01 »
Is ordering off the net an option? Newegg has just what you need.
Offline ironcoder
« Reply #22 on: Sun, 13 September 2009, 05:46:04 »
Yes and not from Newegg, they don't ship out of the country. I could easily find anything I want in America, but I don't live there.
Thanks for the link though, I'll use it to compare over here.
Offline InSanCen
« Reply #23 on: Sun, 13 September 2009, 12:27:51 »
whereabouts are you from? I can link you up to many UK tech site's that sell what you want. A lot will ship to the EU too, if you are located there.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline cmr
« Reply #24 on: Mon, 14 September 2009, 13:40:48 »
what point? that the fglrx driver only works for a very carefully manicured sample of ATI chips? believe me, i didn't miss that. that's the very charge i level at ATI: that their drivers are a mere proof-of-concept, not something i can actually deploy and support. we're not talking about dell OEM cards here. we're talking about AMD factory cards that have been inserted unmodified into the PCI-E slot.
i'm glad to hear that you have the driver working for one card on one box at home, but honestly, that's no justification to be recommending this stuff to other people. nvidia's drivers on linux are so SO much better than ATI's that unless you're being paid by AMD to shill for their junk i can't even begin to grasp why you'd recommend someone go and buy one when you know he intends to use it on linux.
