Author Topic: MX Spring Swap Combination Chart  (Read 2167 times)
Offline Dihedral
  • Mostly Harmless
« on: Sun, 19 April 2015, 08:45:13 »
Some of these hypothetical ones sound interesting - others sound just plain awful :)
If any of these hypothetical ones already exist I'd like to update the chart - also, if you think my hypothetical names are rubbish, your suggestions are appreciated!
Which switches would you want to try?
Offline Giorgio
Re: MX Spring Swap Combination Chart
« Reply #1 on: Sun, 19 April 2015, 18:15:28 »
I was quite sure that there were substantially two springs: light (red switch) and heavy (black switch), and that the other springs differ very lightly, if they were different, from these two.
Last pictures
http://imgur.com/a/RJqM4
« Last Edit: Sun, 19 April 2015, 18:20:39 by gianni »
« Reply #2 on: Sun, 19 April 2015, 18:42:59 »
I call Red and Blacks with Clear switches Ghost Reds or Ghost Blacks.  The name seems to have caught on.  They're much nicer, IMO, than Blacks or Reds.
As for Browns with heavier switches, I think they can just be called **** or scratchy linears.
Offline Dihedral
  • Mostly Harmless
« Reply #3 on: Mon, 20 April 2015, 01:35:35 »
Yep. It's really not a surprise that no one has modded browns. I prefer Ghost linear to my name so ill replace it.
« Reply #4 on: Mon, 20 April 2015, 01:57:22 »
Browns with a heavier spring go from scratchy crap to heavier with a mushy bump. So from bad to worse.
Offline Giorgio
« Reply #5 on: Mon, 20 April 2015, 02:36:07 »
We should stop the egotistical naming conventions and use instead the binomial nomenclature: first the stem type, second the spring.
"The first part of the name identifies the genus to which the species belongs; the second part identifies the species within the genus. For example, humans belong to the genus Homo and within this genus to the species Homo sapiens."
Mx Reddum mx clearum
Would be an mx red with a mx clear spring.
Then we could have the
Mx red gaterus clarus
Mx red spritum 65
Offline azhdar
  • Praise the AZERTY god
« Reply #6 on: Mon, 20 April 2015, 02:42:38 »
Mx red spritum 65
pls tp give gianni his account back.
Azerty Propagandiste
