Author Topic: CST LTRAC Pool Ball Swap Mod  (Read 12850 times)
« on: Tue, 21 April 2015, 18:16:21 »
Quick and easy. Imgur album here. Pool ball feels very slick at first but Clacktalk smacktalk assures me it wears in.
1) Flip over and remove 3 screws. Third screw is under sticker.
2) Remove top and admire the stock ball.
3) Pickup ball. It isn't held in with anything. Admire the mechanical roller mechanisms.
4) Clean pool ball
5) Plop pool ball in between three roller mechanisms
6) Replace cover then turn over and reinstall screws that were removed in step 1
7) Enjoy
Offline clacktalk
  • circa 2015
Re: CST LTRAC Pool Ball Swap Mod
« Reply #1 on: Tue, 21 April 2015, 18:31:54 »
nice to have a reference even though it's a very easy swap!
thank goodness it's easy. i see myself swapping between a 3 and 8 ball very often. for people looking for billiards balls online, ebay has some vendors that have ballz at very sweet prices (at least for CONUS)
diary of a clacktalk
radio_killah: too much frank
« Reply #2 on: Tue, 21 April 2015, 18:48:33 »
My 4 ball is very old.
98103-0
CPT as far as smoothness is concerned actual trackballs feel more buttery but pool balls will keep the bearings clean for longer.
« Last Edit: Tue, 21 April 2015, 18:53:02 by Joey Quinn »
« Reply #3 on: Tue, 21 April 2015, 18:54:47 »
Why's that?
« Reply #4 on: Tue, 21 April 2015, 19:00:33 »
Why's that?
Different surfaces, I've used several balls and each feels different. The smoothness and bearing cleanliness are just things I've noticed.
Edit: Ball weight also affects the feeling
Offline Psybin
  • of Rallos Zek
« Reply #5 on: Tue, 21 April 2015, 19:08:02 »
Heh ball weight
« Reply #6 on: Tue, 21 April 2015, 19:08:18 »
Ah ok. I wasn't sure if you were speaking from experience or some well known fact that I didn't discover yet :).
« Reply #7 on: Tue, 21 April 2015, 19:57:04 »
Dat looks good
« Reply #8 on: Tue, 21 April 2015, 20:01:40 »
Now I want a guide on how to change keycaps.  :P
Hehe. Looks good though! Makes me consider getting an LTRAC...
:confused:
« Reply #9 on: Tue, 21 April 2015, 20:05:46 »
:confused:
1) Douse keycaps in gasoline
2) Light match
3) ? ? ?
4) Profit
« Reply #10 on: Tue, 21 April 2015, 20:20:03 »
:confused:
2) Light match
3) ? ? ?
4) Profit
I just tried this.  Didn't work very well.   :'(  1/10 didn't make any profit.
« Reply #11 on: Tue, 21 April 2015, 20:24:29 »
:confused:
2) Light match
3) ? ? ?
4) Profit
You probably messed up the  ??? step, this procedure is more luck than science.
« Reply #12 on: Thu, 23 April 2015, 05:59:04 »
And somewhere out there there's a person trying to play pool but their set of balls is incomplete.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #13 on: Thu, 23 April 2015, 06:29:14 »
This needs to become more of a thing. I am so jelous...
