Author Topic: What type of connector is this?  (Read 1669 times)
Offline Special K
« on: Tue, 21 April 2015, 21:58:02 »
I bought a Northgate Omnikey 101 off ebay and it came with a cable whose PC end looks like this:
98118-0
Is that an XT connector?  What would be the easiest way for me to use this keyboard?  Do I need to buy a soarer converter?  Is there a cable that plugs into the Ominkey but is a PS/2 on the other end?  What about a cable that plugs into the Omnikey but is AT on the other end?  If so, can I use a blue cube adapter with an AT cable?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline Arcanius
  • Buckling Spring Lover
Re: What type of connector is this?
« Reply #1 on: Tue, 21 April 2015, 22:03:39 »
It's a standard DIN connector. The Omnikey is compatible with both XT and AT, depending on the DIP switch config. All you need is a passive DIN-PS/2 adapter and it'll work with PS/2. The PS/2 can then be put into a Belkin or Blue Cube.
EDIT: There is a manual for the keyboard available on Deskthority. For PC/AT compatibility and standard layout, all the DIP switches should be in the off (down) position.
« Last Edit: Tue, 21 April 2015, 22:05:24 by Arcanius »
Offline Special K
« Reply #2 on: Tue, 21 April 2015, 22:17:07 »
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
« Reply #3 on: Wed, 22 April 2015, 09:48:22 »
Don't be tempted to use a straight male-male PS/2 cable from the Northgate to the motherboard, it won't work.
In the Blue Alps Tour thread I showed how to fabricate a standard PS/2 setup.
- D Trump 2026-10-24
Offline Special K
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
