Author Topic: Filco and Cherry keycaps compatibility  (Read 1849 times)
Offline spremino
« on: Sat, 12 September 2009, 06:30:44 »
In a old post by Ripster, he told us about his experience transplanting keycaps from a Cherry keyboard to a Filco with Cherry switches.
I wonder whether Cherry keycaps have same profile as Filco's. He did that because Cherry's were double shotted, whilst I'm more interested in key feel (durability and more "coarse" surface"), and I wonder whether all mechanical Cherry keyboards share same keycaps quality (double shotted or not).
Any hints? Thanks.
A long space bar... what a waste of space!
Offline huha
« Reply #1 on: Sat, 12 September 2009, 08:53:56 »
Only few Cherry keycaps are two-shot moulded, so you'll need patience and luck finding any. Plastics seem to be identical, though, so you'll get POM or PBT depending on keycap colour.
Filco's keys are taller than Cherry's, so I wouldn't recommend replacing single keys in the alphanumeric area. Replacing everything except shift, return, etc. shouldn't be much of a problem, though, as this doesn't feel extremely weird when typing.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
