Author Topic: What is this switch?  (Read 2438 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Wed, 22 April 2015, 06:27:16 »
I'm sure I've seen it before, but I can't remember what it was. Couldn't find it back on the wiki either.
Offline CaplockJack
Re: What is this switch?
« Reply #1 on: Wed, 22 April 2015, 09:27:50 »
Fujitsu Peerless.
« Reply #2 on: Wed, 22 April 2015, 09:57:15 »
Fujitsu Peerless.
Nope.
Looks to some sort of spring over membrane switch though.
Offline CaplockJack
« Reply #3 on: Wed, 22 April 2015, 11:01:48 »
Oops, I am noob.
Offline chyros
  • a.k.a. Thomas
« Reply #4 on: Wed, 22 April 2015, 11:50:08 »
It's a dome with slider design, but I don't know which one. Looks like they're Alps stems.
« Reply #5 on: Wed, 22 April 2015, 11:52:52 »
If anything it looks like a Futaba Inverse Cross Mount, but it definitely isn't one.
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Wed, 22 April 2015, 13:12:15 »
The switches are Alps-compatible, but the caps that come with them have a longer bar than Alps caps.
I'm very sure I've seen them somewhere before, so they can't be THAT rare, but I can't for the life of me remember where or what it was.
« Reply #7 on: Wed, 22 April 2015, 13:25:18 »
Do you mean they can use Alps caps?  Those sliders are definitely not compatible with Alps housings and I highly doubt they are independent switches that have the same pinout as an Alps switch.
Like I said, I can almost guarantee that's a spring over membrane.
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Wed, 22 April 2015, 13:36:12 »
Oh yeah, I'm sure it is, I can see it beneath the slider xD . Here's a pic of what's under the slider, and the slider from the other side (the system looks almost exactly the same as Fujitsu Peerless).
