Author Topic: Loose Rattly Switch  (Read 1380 times)
Offline themaid
Loose Rattly Switch
« on: Wed, 22 April 2015, 09:31:41 »
Hi, I was wondering if anyone knew how to fix or improve this one switch.  It's a new Ducky Shine 3 and one of the switches doesn't seem as solidly mounted to the case as the others.  With the keycap removed I can shift it around (not the stem, but the black plastic that surrounds it) more than the others, and that key sounds a lot less solid than the others when typing.
Offline CaplockJack
Re: Loose Rattly Switch
« Reply #1 on: Wed, 22 April 2015, 11:04:15 »
Desolder, open up,  and put in a sticker.
Offline MrexD
  • aka mrwoodyxd
« Reply #2 on: Wed, 22 April 2015, 11:30:15 »
Just resolder it.
OP said stem is fine. Just the casing.
Pok3r MX CLears
