Author Topic: Modern ALPS Boards  (Read 3528 times)
Offline Arcanius
  • Buckling Spring Lover
Modern ALPS Boards
« on: Wed, 22 April 2015, 10:41:40 »
Hey all, been a while since I've been active, so I may be out of the loop.
I'm thinking of dipping my toes into the ALPS world. Are there any modern ALPS boards being made at a decent price, besides the Matias? I know the Filco Zero is discontinued. If there's nothing modern, what vintage board would you recommend? Not really feeling an M0110 hardwiring; I'm not lowpoly.
« Last Edit: Wed, 22 April 2015, 15:41:54 by Arcanius »
Offline Special K
Re: Modern ALPS Boards
« Reply #1 on: Wed, 22 April 2015, 11:10:01 »
The last one before the Matias that I know of is the ABS M1, but it is discontinued.
Other than that you are looking at boards that were discontinued in the late 80's - early/mid 90's.  I have personally tried the following:
Dell AT101W (black alps)
Apple Extended Keyboard (orange alps)
Northgate Omnikey 101 (white alps)
Leading Edge DC2014 (blue alps)
BTW, you can search for boards by switch type by using the Deskthority Wiki:
http://deskthority.net/wiki/Alps_SKCM_White
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
« Reply #2 on: Wed, 22 April 2015, 11:13:09 »
The KBParadise V60 is available at mechanicalkeyboards.com. Other than that and Matias, there's no off the shelf current board I can think of.
Vintage? Omnikeys are very nice. Anything Apple is nice (M0116, M0118, etc). For a project, I think the AT101W is solid and you can swap out the Black Alps if you're not into them.
Offline smknjoe
« Reply #3 on: Wed, 22 April 2015, 11:39:40 »
SIIG had one that they sold with white alps clones up until a couple of years ago. It was about $60-$80 at Microcenter.
SSKs for everyone!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Wed, 22 April 2015, 11:45:59 »
Matiases are pretty nice, but they're not the same as old Alps. Moreover, they're expensive. Try to get hold of one of the old standard boards with Alps in for a decent price and see if you like them and want more. Good tryouts are anything with white Alps. In addition to the previous, the Focus FK-2001 (with Alps) is pretty common and good too. Clones range from slightly inferior to noticeably inferior.
Offline gaucho_81
« Reply #5 on: Wed, 22 April 2015, 19:58:01 »
For the sake of you knowing all the options, there is a cheap keyboard made by Tai Hao with ALPS clone switches (around U$S45/50), they are branded Rosewill RK 6000 or Azio Clicker i think.
I have bought the Rosewill, just to satiate my curiosity, and I found that the board is really cheaply made, also the switches feel very uneven across the board (some very clicky, others not so much, even some of them feel almost linear). Only after opening and modify all the clicky leafs of the switches the keyboard become something usable (feels quite good now btw, i will make a post about the mod later). I do this because i love to tinker with this stuff (my neck still hurts a little LOL)  but is not a good keyboard by any mean (beside the switches problems the plastics feel very cheap, the keys are very wobbly, which is normal on alps board but not at this degree, and the legends on the keycaps are just rubish)
BTW: I recommend to you the Matias, I´ve just get one (Tactile pro PC) and I am more than satisfied with the product. Also they are made in your country I believe..
Regards
Gabriel
« Last Edit: Wed, 22 April 2015, 20:06:52 by gaucho_81 »
Offline bahamot
    • bistropolis - dine with style
« Reply #6 on: Thu, 23 April 2015, 09:44:31 »
Love KBP V60MTS' Matias Alps and layout, but don't like its build quality.
Offline chyros
  • a.k.a. Thomas
« Reply #7 on: Thu, 23 April 2015, 10:06:33 »
I wouldn't advise going into Alps clones boards if you have the option to go for a board with real Alps. The latter will almost certainly be cheaper, much more well-built, and with slightly superior feeling and considerably better sound. Old, yes, used, probably, but still better than knockoffs.
Offline Special K
« Reply #8 on: Thu, 23 April 2015, 11:05:47 »
I really like the Filco/Costar cases, so my current project is to take an ABS M1, the only Costar keyboard to use alps clone switches IIRC, and transplant some type of alps switch into it.  I'm leaning toward Matias clicky because I can buy new ones and be sure of the quality, but I haven't decided yet.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
« Reply #9 on: Thu, 23 April 2015, 11:07:08 »
Filco Zero uses Costar like stabilizers. Or do you mean OEM?
Offline Special K
« Reply #10 on: Thu, 23 April 2015, 11:15:07 »
Well the Filco Zero is TKL and I was looking for a fullsize, so that is the main reason I chose the ABS M1.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
« Reply #11 on: Thu, 23 April 2015, 11:19:22 »
Ohhh I see. Now it's all making sense :)
Offline dante
« Reply #12 on: Thu, 23 April 2015, 13:07:21 »
Filco Zero came in a full size as well.
