Author Topic: Lubing Cherry Stabilizers  (Read 5077 times)
Offline awhitedev
« on: Wed, 22 April 2015, 17:06:53 »
I couldn't find a lot of information on this... so I'll ask....
What kind of lube and where should I be lubing cherry stabilizers? i saw this video... is this right procedure?
I think he's using Krytox..
I've used Dupont teflon silicone lube (thin grease) for switches and that has worked out really well for me. Could I use the same lube on cherry stabilizers where the wire meets the stabilizer insert? do i need something thicker? Just curious to see what most folks are doing.
Offline wlhlm
Re: Lubing Cherry Stabilizers
« Reply #1 on: Wed, 22 April 2015, 17:09:30 »
If you don't mind: Ripster's Lube Guide
Offline awhitedev
« Reply #2 on: Wed, 22 April 2015, 19:52:31 »
Ah, thanks! That helps... I figured someone put together detailed info regarding this.  :cool:
