Author Topic: How to fix "mushy" buckling spring keys  (Read 4237 times)
Offline SpacePotatoBear
« on: Thu, 23 April 2015, 21:27:06 »
So I got a Model M how ever the C key and num pad 1 have a mushy feel and don't make a clicking sound, they still work how ever.
I feel like this is the spring wearing or could be dirt in the switch?
how would I go about fixing this - without bolt modding it
Offline FrostyToast
  • Litshoard
Re: How to fix "mushy" buckling spring keys
« Reply #1 on: Thu, 23 April 2015, 21:29:34 »
You can fix it by bolt modding it ;D
Although you could try reseating the cap. Sometimes it doesn't go on properly.
You need to make sure the cap is seated correctly or it will do that.
Quote from: elton5354
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Fri, 24 April 2015, 07:51:21 »
You likely just have misseated springs.
Pull those keys, tilt the keyboard forward so the spring tilts forward in the barrel, and reseat the keys.
