Author Topic: Custom 60% ISO HHKB Keyboard  (Read 4978 times)
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« on: Fri, 24 April 2015, 06:28:33 »
Hi everyone!
I'm going to be using this thread to show off my progress with making a custom 60% ISO HHKB Keyboard aswell as ask question and keep track of everything.
I started with an old beat up CM Quick Fire tk that I harvested browns and a plate from.
Then I went over to http://www.keyboard-layout-editor.com/ and created my layout.
With that I used Swills tool to get a blueprint for the plate I needed to make.
Then I cut up the plate with a dremel to be able to move some keys around and so forth.
And this is where I am now. My next move is to get a 1,5mm aluminum sheet that I'll be using as support to make the whole thing stable when I epoxy glue it. After I've epoxied, sanded, expoxied and sanded again I'll cut out a top layer from 6mm aluminum and use some more epoxy to glue that to the switch plate and the middle layer, sand some more and then paint it. So it'll be a layered design but with the work it'll look like one solid piece except from the bottom that will be removeable. I'll handwire it and control it with a teensy 2.0.
I'll update the post with pictures at a later date if someone is interested :)
Offline Ludovician
Re: Custom 60% ISO HHKB Keyboard
« Reply #1 on: Fri, 24 April 2015, 08:17:30 »
Can you link your layout? I'm curious what you mean by ISO HHKB.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline azhdar
  • Praise the AZERTY god
« Reply #2 on: Fri, 24 April 2015, 08:20:35 »
I guess somehing like that :
source: https://geekhack.org/index.php?topic=67446.msg1724345#msg1724345
with possibly a more HHKb'esque bottom row
Azerty Propagandiste
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #3 on: Sun, 26 April 2015, 09:22:08 »
It's exactly that but with a more "HHKB'esque" bottom row.
To be more precise, it's this one:
Ignore the legends though.
Made some progress today, created the layer that will support the switch plate to make the whole thing stable despite having cut up the original plate in pieces.
