Author Topic: Keycool 84 double keystrokes  (Read 1865 times)
Offline loki993
« on: Fri, 24 April 2015, 10:45:25 »
Hi Ive had my keycool for..I dont know 6 months now maybe. Anyway its stated to double keystrokes, sometimes more, fairly often. I use it for work so as you would imagine sending out an email with words that should have one p and ends up with 2 or 3 is a bit of a problem.
Is there anyway I can fix this? Anyone ever seen this before?
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Keycool 84 double keystrokes
« Reply #1 on: Sat, 25 April 2015, 08:55:03 »
I've got a new KC 87 but an old 84. I've never had this issue with any Kailh switches, but as it's within 6 months you should be able to RMA it.
Offline berserkfan
« Reply #2 on: Sat, 25 April 2015, 09:41:56 »
This problem seems fairy common, but how many keys are suffering?
Offline loki993
« Reply #3 on: Sat, 25 April 2015, 10:49:48 »
It doesnt have Kailh switches its got Cherry Clears.
At least a few but seems like it most common with the P and enter.
