Author Topic: Gateron - MX Stabilizer Clone - Made in China  (Read 12050 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« on: Sat, 25 April 2015, 00:33:48 »
Gateron       www.gateron.com
http://www.gateron.com/page153?product_id=58&brd=1
http://detail.1688.com/offer/43041617408.html?spm=a2615.2177701.0.0.V5Uhlw
https://geekhack.org/index.php?topic=68943.msg1726319#msg1726319
-  Plate mount type only (Samples are coming to me)  -  PCB mount types  >  Not! Exist 25 April
-  Price : 1 pcs = $0.06    1set 10pcs = $0.60     MOQ =100,000 pcs      >   No Wires!  25 Apr.
-  Quality?  : Unknown,  6.25u Wire  Unknown,  7u wire unknown   >  No Wires!  25 Apr.
98438-0
98436-1
« Last Edit: Sun, 26 April 2015, 07:29:27 by sprit »
Offline Dihedral
  • Mostly Harmless
Re: Gateron - MX Stabilizer Clone - Made in China
« Reply #1 on: Sat, 25 April 2015, 00:43:09 »
100, 000 MOQ?
Offline Giorgio
« Reply #2 on: Sat, 25 April 2015, 04:35:21 »
100'000 is not impossible to reach. Just decide that each order should have a moq of 100 pieces, for a total of $6, which translates to 1000 orders.
Sadly, it's more complicated than that, because I highly doubt that wires are included.
100, 000 MOQ?
Offline Prelim
« Reply #3 on: Sat, 25 April 2015, 06:15:36 »
is it just me or their PBT caps look like thick BSP?  :eek: :eek:
http://www.gateron.com/page153?product_id=57&brd=1
MOQ seems to be 1000, however I can't figure out is caps or sets! :/ Since 100¥ is ~$15 it should be the entire set... BSP sets cost ~10 times more, just do the math ;)
http://detail.1688.com/offer/43041557394.html?spm=a2615.2177701.0.0.fSyPuT
« Last Edit: Sat, 25 April 2015, 06:24:31 by Prelim »
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #4 on: Sat, 25 April 2015, 06:55:28 »
I think these are the ones berserkerfan has
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #5 on: Sat, 25 April 2015, 06:58:20 »
Shadovved will probably run a GB for these caps  ;)
(source : [GB] Gateron Switch)
EDIT :
But here are a few numbers :
   - MOQ : 200 sets (or 250 ?)
   - Price per set : $31 (+ shipping)
(source : [IC] thread)
« Last Edit: Sat, 25 April 2015, 07:15:03 by Lpwl »
Offline Prelim
« Reply #6 on: Sat, 25 April 2015, 08:20:27 »
EDIT :
nice to know, but $31 for a set which cost $15 on Gateron? lol... guess I'll making GBs myself @@
Offline Flyersfan1
  • Hi!
« Reply #7 on: Sat, 25 April 2015, 08:26:41 »
I hope these are better than the Hammer branded stabilizers, those suck.
Quote from: Photekq
Offline Lpwl
    • My O-ring Store
« Reply #8 on: Sat, 25 April 2015, 08:37:03 »
Hammer ones are PCB-mounted.
(image from imsto.cn)
Offline MrexD
  • aka mrwoodyxd
« Reply #9 on: Sat, 25 April 2015, 08:45:42 »
I'd love to replace the stock poker stabilisers.
spacebar wire is bent and causes rattle though.
hope these come with wires
Pok3r MX CLears
Offline sprit
« Reply #10 on: Sat, 25 April 2015, 10:00:26 »
Been dreaming of New Transparent stabs for years, feeling building new moulds will not that necessary at this moment, got 3-4 contacts to produce Black stabs at high Moq w poor or ordinary quality,  but i want transparent n -lucent !   Someday my things will come?    :rolleyes:
« Last Edit: Sat, 25 April 2015, 10:28:04 by sprit »
Offline Giorgio
« Reply #11 on: Sat, 25 April 2015, 11:09:00 »
Surely transparent stabs are much less resistant to abrasion and offer more resistance, plus they are much more fragile.
Offline sprit
« Reply #12 on: Sun, 26 April 2015, 01:54:21 »
I guess you just need To replace the spacebar wire only,   I got some custom stainless wires made at a factory, if you need it, pm me  :)
Offline sprit
« Reply #13 on: Sun, 26 April 2015, 07:08:50 »
Reply from Gateron,  for Stabs
:  Plate mount type only,  No Wires!
不能拿来做透明的pc/abs
收缩率不同,模具尺寸不一样,做出来的产品尺寸不一样的
黑色的,可以报给你
但是,我们没有卫星轴的钢丝
Unable to use Transparent PC/ABS material (into the current ABS dedicated mould)
Due to the plastic shrink ratios differ,  the dimensions of the moulds differ in details
Current Black ABS plastic parts are available
But, we don't have metal wires for stabilizers
98605-0
« Last Edit: Sun, 26 April 2015, 07:15:58 by sprit »
Offline StinkyTheDonut
  • I like rubber domes.
« Reply #14 on: Sun, 26 April 2015, 19:05:54 »
I've been looking at those white costar stabs on taobao.
They seem to look translucent like Gateron switch housing.
They aren't cherry stabs, but they are probably the next closest to your dream. lol
I'm want to get some but I can't seem to find any information about their quality. =(
I only have a washable keyboard.
Offline wlhlm
« Reply #15 on: Sun, 26 April 2015, 19:39:50 »
Can you post a link to the stabs?
« Reply #16 on: Mon, 27 April 2015, 01:37:46 »
Here's a link to a random vendor with pics.
http://item.taobao.com/item.htm?spm=a230r.1.14.58.GjEDPM&id=43764958283&ns=1&abbucket=16#detail
Many of the vendors seem to sell both blacks and whites for both the inserts and plate mounts, but only have images of the blacks.
Offline wlhlm
« Reply #17 on: Mon, 27 April 2015, 01:39:42 »
« Reply #18 on: Mon, 27 April 2015, 01:46:34 »
Offline sprit
« Reply #19 on: Wed, 29 April 2015, 06:33:15 »
No problem
Thanks here too!   Still looking for quality MX Stab clones   ;)
