Author Topic: Whats the best way to remove key nubs?  (Read 79360 times)
Offline wellington1869
« on: Sun, 13 September 2009, 07:58:13 »
Whats the best way to remove this nub?
A carpenter's chisel?
Small sharp knife?
Fine sandpaper followed by polishing paper? (I'd like to leave the key looking as normal as possible though) :)
Buy a normal D key? :)
« Last Edit: Sun, 13 September 2009, 07:58:56 by wellington1869 »
using: ms 7000/Das 3
Offline Rajagra
« Reply #1 on: Sun, 13 September 2009, 08:29:53 »
I'd say buy replacement keys or leave them as is. If this is to allow a different layout, give the new home keys even bigger nubs so there is no confusion.
« Reply #2 on: Sun, 13 September 2009, 08:39:58 »
I suppose I could put at101w keys on here. I kind of like the light beige and font of the aek switches though. Maybe a bigger nub like you say. I'll have to buy more nubs from hoolean.
I'm still wondering if a delicate shaving operation couldnt whittle it down though. I do have a dremel :)  If i'm going to replace the keys anyway, I might give it a try to see what happens.
« Reply #3 on: Sun, 13 September 2009, 09:19:35 »
Thanks rippy! As far as the rubbing method, you mean just with your finger or something? (trying not to picture it really).
I'll try the chisel too. I might have to buy a thin chisel from home depot or something.
« Reply #4 on: Sun, 13 September 2009, 09:24:09 »
I wonder if my sharp penknife could cut it off if I cut "west to east" along the curve of the keytop.
Offline nanu
    • http://T-T.be/portal
« Reply #5 on: Sun, 13 September 2009, 14:23:10 »
Depends on how soft or brittle the plastic is, I guess. Hard to say if I would try a Dremel cutoff wheel, going very slowly, whether that gives more control than having to potentially exert high force with a knife.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #6 on: Mon, 14 September 2009, 04:20:50 »
1)  razor blade would do fine (number 11).
2) sharpened screwdriver (flathead)
3) unsharpened small screwdriver (flathead, eyeglass or jewelers)
4) round front flush cut nail clipper (pushed hard into the cap)
5) knife, just use the tip
6) heat up a pin, paperclip, thin metal rod and push it down
7) a file
8) sand paper
9) dremel or any small rotary type tool (almost any attachment would do it)
10) chisel small, large
11) make a chisel (use dremel to sharpen a piece of metal)
12) flush cutters
13) Drill a hole or twist a hole with an x-acto knife (number 11 blade)
14) try a tiny bit of acetone on it
15)....
.........sorry, I am really bored right now =P
Whatever you use there will be either some clean up still required and/or a small or large spot with a different texture. You could remedy this by changing the texture of the whole key (and most likely lose the letter printed) or selectively adding a small bit of texture back in.
I guess if I had to do this and had a very limited range of tools available, I would just use a sharp knife or x-acto and shave it down lightly and slowly.
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline itlnstln
« Reply #7 on: Mon, 14 September 2009, 08:20:54 »
A bench grinder.
Offline timw4mail
    • https://timshomepage.net
« Reply #8 on: Mon, 14 September 2009, 09:45:07 »
Really, the nubs on the D and K keys bother you that much?
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline rdjack21
« Reply #9 on: Mon, 14 September 2009, 10:18:25 »
Quote from: itlnstln;117732
A bench grinder.
With a polishing wheel to make it shinny while you are at it.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline rdjack21
« Reply #10 on: Mon, 14 September 2009, 10:22:52 »
Quote from: ripster;117749
Well, since we're getting creative.
Magnifying glass?
A result of RD's son's experiments here.  I don't let my son play with my keyboard's nubs.
Yea he was having fun that day but when he came in the house and wanted one of the keys off my customizer I had to put a stop to it. Still think that the way the key melted looks kinda interesting.
Keyboards
Black Alps: ABS M1
Offline itlnstln
« Reply #11 on: Mon, 14 September 2009, 10:30:51 »
Quote from: rdjack21;117757
It sort of looks like it's crying.  Poor thing.
Offline itlnstln
« Reply #12 on: Mon, 14 September 2009, 10:55:07 »
Holy sh*t! What's the down-force on that thing? I would think driving that would make the back tires rub on the wheel-well.
Offline rdjack21
« Reply #13 on: Mon, 14 September 2009, 11:20:18 »
Quote from: ripster;117763
I feel so superior in my Honda Odyssey.   At least it's not pretending to be something it's not.
:rofl: That link is just too much but I have to say I love the comment on this one:
Nothing better than investing a fortune on a proper racing spoiler and bolting it onto a **** car!
Just brilliant!!
Keyboards
Black Alps: ABS M1
Offline itlnstln
« Reply #14 on: Mon, 14 September 2009, 11:48:47 »
Quote from: rdjack21;117769
Just brilliant!!
Hey, those Ford Festivas could haul ass.  Especially, if you could pedal fast.
« Reply #15 on: Mon, 14 September 2009, 12:22:07 »
Quote from: clickclack;117718
7) a file
8) sand paper
12) flush cutters
15)....
click, you're absolutely right. I'll try the xacto first. Dont know why i didnt think of that ;)
« Reply #16 on: Tue, 15 September 2009, 13:05:00 »
btw I "solved" this by (as someone suggested above) sticking a much larger stick-on nub on the J and F keys... after doing that the smaller nubs on the D and K havent bothered me.
I tried attacking those small nubs with an xacto and etc, but they're so small that the knife kept slipping off it. Didnt want to take a chance of ruining the key.
« Reply #17 on: Tue, 15 September 2009, 13:22:18 »
well my board has four nipples now. I guess its a nub-orgy.
Offline itlnstln
« Reply #18 on: Tue, 15 September 2009, 13:46:05 »
Quote from: wellington1869;118144
Freak.
« Reply #19 on: Tue, 15 September 2009, 15:09:51 »
So has anyone here named their girlfriend's breasts "F" and "J"?
Come on, 'fess up.
Offline timw4mail
« Reply #20 on: Wed, 16 September 2009, 08:46:59 »
Why must these discussions always degrade this way?
Offline itlnstln
« Reply #21 on: Wed, 16 September 2009, 08:50:16 »
You say "degrade..."
Offline Rajagra
« Reply #22 on: Wed, 16 September 2009, 10:45:21 »
Quote from: timw4mail;118383
If you are concerned about equality, here's something for the ladies:
Offline o2dazone
« Reply #23 on: Thu, 17 September 2009, 00:31:45 »
Quote from: wellington1869;118185
Come on, 'fess up.
lol
Offline lal
« Reply #24 on: Thu, 17 September 2009, 04:04:52 »
Come on, 'fess up.
Not until your suggestion.  She wouldn't let my fingers find their home row even when commending on her beautiful F and J ;)
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline DreymaR
  • Colemak forum guy
    • DreymaR's Big Bag of Kbd Tricks
« Reply #25 on: Thu, 17 September 2009, 04:46:08 »
Come on, 'fess up.
You low-down pervy sleaze. It's "T" and "N". Even fits with "tit" and "nip".
Much like the poor old-fashioners have to game with a wishy-washy WASD block whereas the enlightened ones go to WARS!  ;)
Better burden you cannot carry than man-wisdom much ~ Hávamál
Offline JBert
« Reply #26 on: Thu, 17 September 2009, 05:05:45 »
With a nod to the 'board wars thread:
The colemak is strong with this one...
« Last Edit: Thu, 17 September 2009, 05:09:48 by JBert »
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline clickclack
« Reply #27 on: Thu, 17 September 2009, 05:17:30 »
Quote from: ripster;118189
Nope, but she has letters IN her bra.
You have a gift buddy :)
Great powers come with great responsibility!
