Author Topic: IBM AT $130 Shipped BIN, ends soon  (Read 1427 times)
Offline E TwentyNine
    • Some of My Keyboards
« on: Sat, 25 April 2015, 09:46:30 »
Surprisingly didn't see this here already...
http://www.ebay.com/itm/IBM-Model-F-PC-AT-Keyboard-84-Key-Mechanical-Clicky-Buckling-Spring-/261827315570
The pictures show it hooked up an working.  It's missing the legs but I use the AT flat and it's fine.
Offline ander
  • I type, therefore I am
Re: IBM AT $130 Shipped BIN, ends soon
« Reply #1 on: Sun, 26 April 2015, 01:02:39 »
Unfortunately, it's also missing the side leg handles, which are a pretty distinctive part of the AT's appearance.
« Reply #2 on: Sun, 26 April 2015, 06:27:59 »
The side handle is part of the leg piece.   If the leg's missing, the handle's missing.
« Reply #3 on: Sun, 26 April 2015, 16:03:44 »
I think those "ear tabs" are silly-looking and vulnerable to breakage.
They can be sanded down smooth (harder than you might expect) and they will not sit perfectly straight in the hole (which they didn't before, but it was hard to notice) and look quite normal.
Also, XT and AT types are not compatible.
- Franklin Roosevelt 1933
