Author Topic: Dell Quietkey SK-8000 not working. Ideas?  (Read 3215 times)
Offline capitantortuga
« on: Sat, 25 April 2015, 20:05:25 »
So I picked up a free old but I think new Dell Quietkey SK-8000 PS/2 keyboard but it doesn't seem to be working. The only key that does anything is the num lock key which turns the LED on. Other than that it doesnt seem to be working. I inspected the keyboard controller and it seems fine. Any suggestions? Drivers? Thanks
Re: Dell Quietkey SK-8000 not working. Ideas?
« Reply #1 on: Sat, 25 April 2015, 20:13:07 »
Do you have a single PS/2 port or one for keyboard and one for mouse, or are you using a USB adaptor?
Some keyboards don't like shared ports or standard USB adaptors, I have no idea if this board is one of them but more info is always a good thing :)
« Reply #2 on: Sat, 25 April 2015, 20:18:38 »
My motherboard has 2 PS/2 ports, one for mouse and other for kb. Currently it is connected to the PS/2.
« Reply #3 on: Sat, 25 April 2015, 20:27:06 »
Here's what it currently looks like. It feels pretty nice...except that it doesnt work  ;D,haha. https://www.dropbox.com/sc/p432tmrdlj9j4vn/AAB_63vtW3_8s_eFgRQU_pPBa
Offline CaplockJack
« Reply #4 on: Sat, 25 April 2015, 21:27:49 »
Did you try reboot?  You can't hot plug PS/2.
« Reply #5 on: Sat, 25 April 2015, 21:38:28 »
I did not....I'll get right back to you then. I did not know that about PS/2
« Reply #6 on: Sat, 25 April 2015, 21:43:07 »
So i just restarted and the keyboard is working great( typing on it right now) feels good man  :D. Thanks for the help. PS/2 was a bit before my time so I did not know that you can't hot plug it. The more you know...
