Author Topic: Replacement cable for Omnikey 101  (Read 2109 times)
Offline Vanilla
  • 110% Snuggable
« on: Sun, 26 April 2015, 03:33:05 »
Picked up another one of these bad boys sans the stock cable that originally came with it. The original *removable* stock cable has a ps/2 male (keyboard side) with DIN 5 male (computer side).
Just running this through you guys: in the great unlikelihood of me finding an exact replacement, would I be okay to simply run a ps/2 male to male cable in place of the stock one described above?
Because all I believe is that the stock cable simply has the pin outs of the ps/2 matched to the din-5. Nothing proprietary at least to my knowledge.
Offline Vanilla
  • 110% Snuggable
Re: Replacement cable for Omnikey 101
« Reply #1 on: Sun, 26 April 2015, 03:38:36 »
Also, any sources for a right angled ps/2 male to straight ps/2 male cable?
Offline jacobolus
« Reply #2 on: Sun, 26 April 2015, 04:33:16 »
Sure, PS/2 and AT are the same protocol. The only difference is the physical connector at the end.
« Reply #3 on: Sun, 26 April 2015, 10:11:46 »
Nope, a straight PS/2-PS/2 cable will not work.
In post #157 of Akimbo's thread I detail how to build a conventional PS/2 connection using a discarded cable from a donor board.
https://geekhack.org/index.php?topic=49604.50
- D Trump 2026-10-24
Offline Vanilla
  • 110% Snuggable
« Reply #4 on: Sun, 26 April 2015, 16:32:59 »
Yeah it seemed to good to be true  :))
This was exactly what I was looking for, thanks!
Offline jacobolus
« Reply #5 on: Sun, 26 April 2015, 19:45:30 »
Offline jevvix
« Reply #6 on: Mon, 27 April 2015, 02:41:26 »
I'm fairly certain I have an original Omnikey cable I'd sell. If you're interested, drop me a PM and I'll look for it tomorrow.
