Author Topic: Good Dual PS2 to USB adapter?  (Read 1400 times)
Offline Sygaldry
  • Edema Ruh
« on: Mon, 27 April 2015, 20:39:02 »
Would like to use my recently acquired IBM M13 on my laptop and am confused by the sheer amount of adapters available.
Is there a generally well received dual PS2 to USB adapter out there?
(Not really considering the Soarer or the Blue Cube because they only have 1 PS2 connection).
null
Re: Good Dual PS2 to USB adapter?
« Reply #1 on: Mon, 27 April 2015, 20:46:57 »
I have had had excellent success 90%+ of the time with cheap crap like this:
http://www.ebay.com/itm/USB-Male-to-PS2-Female-Cable-Adapter-Converter-Use-For-Keyboard-Mouse-D1-/321289683058?pt=LH_DefaultDomain_0&hash=item4ace5b8072
but a lot of people think that you need quality stuff.
Also, Chinese junk takes 3 weeks.
- D Trump 2026-10-24
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #2 on: Mon, 27 April 2015, 22:20:07 »
I have had really good luck with the Belkin dual PS/2 to USB adapter.
(I don't know if they make/sell them anymore)
The Cables-2-Go 32185 adapter works too.
The Trendnet TU-PS2 USB to PS/2 Converter works as well.
All 3 do work with both.
Edit: Yes M13.
« Last Edit: Mon, 27 April 2015, 22:24:44 by Snowdog993 »
