Author Topic: New Filco Squeeking space bar  (Read 2110 times)
Offline azkurz
« on: Sun, 13 September 2009, 17:56:59 »
I've had my Filco Majestouch for a week now and noticed the space bar squeeks everytime I hit it with my right thumb. Is this something that will go away or do I need to put some lube on it and tap that thing?
Offline yode
  • s a d b o y s
« Reply #1 on: Mon, 14 September 2009, 01:36:04 »
Quote from: azkurz;117652
o lawd
300 OTF GBE OBLOCK ON BD
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #2 on: Mon, 14 September 2009, 18:31:22 »
Maybe you should take it apart and put it back together again. That usually fixes problems like that.
Offline ironcoder
« Reply #3 on: Tue, 15 September 2009, 03:33:03 »
Especially if you drop it from excessive heights. That fixes almost anything.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
« Reply #4 on: Tue, 15 September 2009, 18:19:11 »
Try hitting it on the side as well. That fixed my monitor when everything it showed turned yellow.
