Author Topic: Most Affordable fully Programmable 60%?  (Read 2200 times)
Offline Tiramisuu
« on: Tue, 28 April 2015, 11:22:24 »
I have been faithful  to my Poker 2.  New caps,  a nice aluminum case...  But I want more.   There's something missing from the relationship.  I want programmability...  I  want Bluetooth....  I want sparkles.....
I'm also a cheapskate, otherwise I'd already have a Gon.
What are my gateway drugs after the Poker?
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline Giorgio
Re: Most Affordable fully Programmable 60%?
« Reply #1 on: Tue, 28 April 2015, 11:34:24 »
Just replace the pcb. These options are in the $50 range, you need to add the switches ($40).
Winkeyless
Gon
Gh60
Offline Sygaldry
  • Edema Ruh
« Reply #2 on: Tue, 28 April 2015, 11:38:36 »
Buy a NerD 60 PCB from GON with the bluetooth option (buying a plate is optional). Use your Poker II case. Sell the Poker II internals (probably won't get much for it but it'll offset some of the cost).
Problem solved =]
null
Offline Giorgio
« Reply #3 on: Tue, 28 April 2015, 12:21:41 »
If you want the plate (many say that you really need it), there is a gb starting the 5th of may. 20 Euro delivered. Ansi and iso.
Offline asgeirtj
« Reply #4 on: Tue, 28 April 2015, 15:24:40 »
Winkeyless
Gon
Gh60
Do these options have comparable programming capababilities?  I'm curious since I'm quite clueless about programming :)  Also are wireless keyboards through bluetooth a thing?  Any disadvantages to that ?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline KHAANNN
« Reply #5 on: Wed, 29 April 2015, 13:06:53 »
Winkeyless
Gon
Gh60
Unless you lie down with your keyboard or sth, bluetooth/wireless just bugs things in general
Keyboard is generally a non-moving peripheral, so wires are nice
plus, can you sleeve a bluetooth signal? I think not.
Offline Giorgio
« Reply #6 on: Wed, 29 April 2015, 14:02:27 »
I hate bt keyboards, because it's often difficult to obtain these things: security, simplicity, ease of configuration, bios access, autonomy, stability.
Offline Tiramisuu
« Reply #7 on: Wed, 29 April 2015, 18:06:12 »
My logitech di novo edge is bluetooth and works perfectly.   The battery has lasted without replacement for 6+ years.   It lasts about a week on a single charge and is fantastic on the desk or in the living room.
This is based on pre-bluetooth le and is just about the nicest keyboard I have ever owned.
The anti bluetooth message is bs.
Offline Giorgio
« Reply #8 on: Wed, 29 April 2015, 18:54:41 »
You really charge your keyboard once a week??? I was sure that it lasted about a month, and also that it seemed too much. Go figure.   :eek:
You will encounter problems that I will never have....  :))
https://bugs.launchpad.net/ubuntu/+source/bluez/+bug/269851
I won't talk about the security of your 6 years old keyboard. Someone could know where you live  :))
