Author Topic: Shine-through keycaps for Gateron LED switches?  (Read 4836 times)
Offline Ruthalas
« on: Tue, 28 April 2015, 14:53:54 »
Hey GH, I have a question you may be able to help with.
I just got in the current Massdrop for a Varmilo VA87MR, which has backlighting.
I notice that the Gateron switches have the LED portion on the southern/bottom portion of the switch (opposite the LED positioning on LED Cherry switches as far as I can tell).
Do I have any options for shine-through keycaps?
The Vortex PBT sets that show up on Massdrop occasionally look great, but I suspect would have issues due to the LED placement.
If anyone could give me some guidance, or even try this if they have a similar board and caps, I'd be very appreciative!
Offline Sygaldry
  • Edema Ruh
Re: Shine-through keycaps for Gateron LED switches?
« Reply #1 on: Tue, 28 April 2015, 14:55:17 »
LED placement depends on PCB not the switch.
null
Offline tbc
« Reply #2 on: Tue, 28 April 2015, 14:56:49 »
if you look closely at the cherry switches you're talking about, you'll notice that the cherry branding is upside down.  ;)
Offline Ruthalas
« Reply #3 on: Tue, 28 April 2015, 15:00:44 »
Hmm. Ok, well the Gaterons are mounted such that the LEDs are below the switch stem:
Wouldn't that cause issues for typical shine-through caps?
Offline nightdriver
  • life is like t. rex
« Reply #4 on: Tue, 28 April 2015, 16:11:55 »
yes, for the vortex keys, you'd probably only get the number row illuminated.  i haven't seen any standalone shinethrough keys with that layout.  they mostly only come with the keyboards that have the bottom LEDs.
Offline Ruthalas
« Reply #5 on: Tue, 28 April 2015, 17:01:44 »
Ah, that's too bad. Thank you for the information though!
(If anyone sees this thread and knows of a set that'd work, I'd love to hear about it!)
