Author Topic: Blackberry as a wireless keyboard/mouse  (Read 2388 times)
Offline pyro_
« on: Wed, 29 April 2015, 05:33:20 »
Hi, I recently found geekhack while searching for sources to try and help me accomplish this, hopefully this is the right subforum :/.
As the title suggests, I want to get an old broken blackberry with a working keyboard on it, and then be able to use it as a wireless keyboard (with the USB receiver) (and possibly use it as a mouse). I don't have much electronics knowledge but I am eager to learn :3.
I am not necessarily after spoon-feeding, a push in the general direction and names of things I should be searching for would be helpful :)
Thanks,
pyro_
Re: Blackberry as a wireless keyboard/mouse
« Reply #1 on: Fri, 01 May 2015, 02:29:59 »
The keyboard is probably a little matrix, if the controller isn't built in you could connect it to a Teensy (or similar) just like you would a standard switch matrix.  Then connect the Teensy to a USB to bluetooth board (adafruit has one) and it will work.  If the controller's built in see the below - same story.
The "mouse" would be the trackball/optical thing?  It's probably very small and proprietary so you'll have to work out what the pins do (unless you can find something online where someone's already done it)  Part of this will mean putting voltage into it and if you put it in the wrong place there's a chance you'll damage it, so be prepared to buy a couple.  Reverse engineering hardware (working out how something works without documentation) isn't really a beginners topic but I wish you luck if jump in the deep end.
As an alternative to using the actual mouse you can configure keyboard keys to move the cursor, it's less accurate but I guess this is only for occasional use so it could work.  Not sure if the Blackberry keypad will allow you to press any random keys together (search: switch matrix diodes) but some shouldn't conflict.
Once you have anything working you'll need to cram it all in the case which will be a challenge in itself.
This is deliberately vague as you didn't want the spoon - this is the right place if you have any questions :)
