Author Topic: Best way to clean stained laser infill legends?  (Read 2060 times)
Offline ctm
  • Hello, world!
« on: Wed, 29 April 2015, 15:14:15 »
I have tried alcohol and soap, but neither works. Any suggestions?
Coming:
Ellipse Model F F62.
Offline Muffin860
Re: Best way to clean stained laser infill legends?
« Reply #1 on: Wed, 29 April 2015, 15:19:49 »
What did you use to scrub with? Id think a toothbrush would work well.
IBM Model M
Offline Firebolt1914
  • POM Overlord
« Reply #2 on: Wed, 29 April 2015, 15:34:39 »
Have you tried soaking them with denture cleaning tabs for like 24 hours if necessary?
Offline ctm
  • Hello, world!
« Reply #3 on: Wed, 29 April 2015, 16:00:01 »
I just tried scrubbing it with a toothbrush with soap and it does not seem to work. I also tried using an eraser but it does not seem to clean the stain but wears down the keycap (ABS) a little. I am thinking about using denture tabs. Does anyone have successful experience with denture tabs?
Coming:
