Author Topic: KB-78 - need software to rebing [reprogram], preferably on linux  (Read 1557 times)
Offline polishprogrammer
Hello
I recently got a KB-78 pos keyboard, and i need to reprogram the bindings. The provided software doesnt work on Linux wine nor WinXP on virtual box, and i dont have winXP/98 machine to program the board.
Do you know ANY way to rebing the keys?
Thakns in advance,
Chris.
Offline drewdavis
Re: KB-78 - need software to rebing [reprogram], preferably on linux
« Reply #1 on: Thu, 30 April 2015, 09:20:00 »
By reprogram you mean remap the keys? If not please ignore what I've written below.
I use xmodmap, personally. Google should have some good tutorials for you.
Alternativly inidividual DEs and WindowManagers will have their own built in way to remap keys as well, but xmodmap will follow you between DEs.
« Reply #2 on: Thu, 30 April 2015, 09:40:50 »
I was thinking about xmodmap, but the keyboard has chars encoded to different keys. I need to reprogram the eprom in the device and give it new mapping.
ie.
the key labeled "cash" sends '+' signal to the pc. I need to change it that it sends 'enter' (for example)
