Author Topic: I need some help  (Read 1737 times)
Offline dothm
I need some help
« on: Fri, 01 May 2015, 01:58:18 »
Hello Geekhack coming from New Zealand
I need someone to check the measurements of my 60% case i made (in sketchup cause i'm a noob) to see if everything is laid out correctly. I used a poker plate drawing from swill's plate building tool to get the standoffs in the correct position (6 mm deep) and I guesstimated where the micro usb slot goes. Once this case is finished i'm planning on making this case open source.
P.S I'm not a hobbit
* Poker Case.skb (344.79 kB - downloaded 173 times.)
Ergo Clear White Carbon Filco TKL
