Author Topic: Need help with TKL MX Reds model  (Read 1769 times)
Offline chocomarshmello
« on: Fri, 01 May 2015, 05:27:50 »
Hi guys, I'm new here but I thought I'd just start my first post with a question.
So, I'm looking for an affordable TKL kb that is easily customizable for the stealth/ninja look (side printed letters, not completely blank), which models should I be looking at? The Filco is just too expensive for me. If I had £££ then the Filco Ninja TKL would be "the one".
I've seen the Corsair K65 for £70 which isn't too bad, but I've read that you can't exactly swap out all the keys because of their own keycap design. Eventually I would like my keyboard to look something like this. And perhaps with red WASD keys as well:
I can't seem to find the cheaper CM Storm TKL stealth models here either, but from the US Newegg reviews, it looks like they easily break after a couple months of usage.
Any ideas?
Offline GenKaan
  • Mer caps, mindre käbbel
Re: Need help with TKL MX Reds model
« Reply #1 on: Fri, 01 May 2015, 05:46:49 »
The K65 dose not have standard layout, so I would avoid that if you are going for a custom set
I found my Shine 3 used for like $80, so a used keyboard opens up a lot if your budget is around ~$110
If you dont care about LED's or LED quality, the CM Rapid-i is within your budget I believe.
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline Dext
« Reply #2 on: Fri, 01 May 2015, 05:48:24 »
Cooler Master has some TKL that arn't too expensive like the Quick fire rapid i (http://gaming.coolermaster.com/en/products/keyboards/rapid-i/). They have many TKL with red switches.
« Last Edit: Fri, 01 May 2015, 05:50:42 by Dext »
« Reply #3 on: Fri, 01 May 2015, 05:55:27 »
What is the build quality like for the CM Storm QFR? Are they as bad as some reviewers make them out to be? I found a thread here dedicated to tricked out QFR's.
I don't care for the LEDs since I'm looking for a clean solid look. I've contemplated getting a used Ducky/Filco but worry about the lack of warranty considering a used one still comes with a high price tag.
From what I've seen after a bit of googling I've found that brand new, there's no price difference between a Ducky DK2087S and a QFR-i which is £90. A Filco is £100... so I really have no idea what is the best value for money here.
« Last Edit: Fri, 01 May 2015, 07:01:43 by chocomarshmello »
Offline Dext
« Reply #4 on: Sat, 02 May 2015, 06:55:51 »
A topic has been created here : https://geekhack.org/index.php?topic=71450.0
« Reply #5 on: Sat, 02 May 2015, 15:35:05 »
I can't seem to find the QFR Stealth TKL anywhere in the UK. Was a version not made for Europe?
