Author Topic: [GB] CF-LX: Carbon Fiber 60% Case [DONE]  (Read 990624 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: [GB] CF-LX: Carbon Fiber 60% Case (PRODUCTION)
« Reply #500 on: Thu, 11 February 2016, 09:21:30 »
Do they only have like two employees or something? ;)
Well as you saw a bit earlier, they already lost one :p
Offline Ngt
« Reply #501 on: Fri, 12 February 2016, 03:17:01 »
Well even though it doesn't move fast, at least it moves forward. At this point we've waited so long that it would be nice it eventually delivers. Thanks for keeping us updated Hwood and for your work. Considering you are at Uni, it might not be the easiest for you.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #502 on: Fri, 12 February 2016, 15:07:36 »
He sent the first three cases out today :D
« Reply #503 on: Fri, 12 February 2016, 16:01:49 »
Fantastic news!!!!!
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #504 on: Fri, 12 February 2016, 16:20:37 »
Niiiiiiiiiiiiiiiiiiiiice  :cool:
Offline VentureG
« Reply #505 on: Fri, 12 February 2016, 16:48:41 »
Hwood is giving me the hwood.
Offline axtran
« Reply #506 on: Fri, 12 February 2016, 17:36:00 »
I am so excite!
MX Silent > MX Vintage Black > Everything Else
Offline user 18
« Reply #507 on: Fri, 12 February 2016, 17:46:24 »
I'm excited to see these! Make sure you post some pics when you get them!
Avatar by ashdenej
Offline Ngt
« Reply #508 on: Mon, 15 February 2016, 03:17:54 »
I'm pretty sure that's his intention! Especially since Hwood does really nice pictures!  :-*  Looking forward to see that as well. :D
Offline lashiel
« Reply #509 on: Mon, 15 February 2016, 11:13:27 »
So now that the end feels in sight, what kinds of builds are people planning? Switches, keysets, etc.
« Reply #510 on: Mon, 15 February 2016, 11:22:29 »
I've decided on an Infinity board with Cherry MX switches. I don't have a clue on a keyset though.
Offline VentureG
« Reply #511 on: Mon, 15 February 2016, 11:23:07 »
I've had a b. Face and switch stickered, lubed ergo clears for about 9 months. Just got carbon last month.
Offline Vimto
« Reply #512 on: Mon, 15 February 2016, 11:39:44 »
B.Face and either Gateron Blues, or Zealios.
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline Hellcatz
« Reply #513 on: Mon, 15 February 2016, 12:02:32 »
black purple and gold
Offline exitfire401
  • The Force is Re/\l
« Reply #514 on: Mon, 15 February 2016, 12:12:36 »
This is one of the very few purchases I've made without a plan for it...really need to figure out what I want to do with this case.
« Reply #515 on: Mon, 15 February 2016, 12:26:16 »
This is what it will look like to start with
  • Happy config.
  • Blank Gateron PBT (light grey alpha and dark grey mods) with blank CMY Mod Pack.
  • B.Face PCB.
  • Ergo clear alphas, linear modifiers  :thumb:
Offline axtran
« Reply #516 on: Mon, 15 February 2016, 13:38:13 »
I'm currently making Vintage Blacks in Vintage Brown PCB mount bases, stickered and lubed with 55g SPRiT springs. As for PCB, I'm trying to convince myself to put in an order for a GON NerD 60 PCB.
Offline xondat
  • i'm not a star
« Reply #517 on: Mon, 15 February 2016, 16:42:49 »
Excited to see how this turns out, I wasn't around when this started but I get a hard on for carbon :p
Offline eeymiel
« Reply #518 on: Mon, 15 February 2016, 18:56:11 »
I've got zealios, a gon nerd 60 and a carbon black keyset waiting for this case.
Offline lashiel
« Reply #519 on: Mon, 15 February 2016, 22:03:14 »
Oooh nice. I seriously considered Carbon Black, but I think I'm going to give Deep Space a try. Go for a purple and black theme instead of just black.
Offline Ngt
« Reply #520 on: Tue, 16 February 2016, 01:49:54 »
  • Happy config.
  • B.Face PCB.
Haha we pretty much have the same config. Just instead of the ergo clear I will put 65g tactile zealios in it. Well for the keyset I'll be switching between the blank gaterons, hyperfuse and hack'd by geeks.
PS: forgot to mention I have a middle piece with RGB on the PCB as well.
« Reply #521 on: Tue, 16 February 2016, 14:08:21 »
  • Happy config.
  • B.Face PCB.
We have similar taste. Only my 65g Zealios ended up in my Compact SQ and I'm still waiting for my Hack'd to be delivered (FML)!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #522 on: Wed, 17 February 2016, 12:04:33 »
« Reply #523 on: Wed, 17 February 2016, 12:15:12 »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #524 on: Wed, 17 February 2016, 13:00:44 »
So, tiny problem. Turns out I wasted like $50 buying standoffs that are too long.
Can someone tell me which configuration of these screws would work with these standoffs
these?
« Last Edit: Wed, 17 February 2016, 13:19:11 by hwood34 »
Offline axtran
« Reply #525 on: Wed, 17 February 2016, 13:58:57 »
these?
I recommend seeing if the similar measurements that olkb.co uses for Plancks would work (I think they're metric though). I can help look into this a little bit later.
« Reply #526 on: Wed, 17 February 2016, 14:11:25 »
these?
Those standoffs are going to be 1/4in long which will leave the case shorter than most sandwich cases. I'd recommend 3/8in standoffs because it'll leave the keycaps at a regular 3/4in height (from cap bottom to table) and 1/4in will result in usb clearance issues. Also if anyone plans on hand wiring a 1/2in standoff will be necessary because the teensy needs more clearance.
As far as screw length goes just divide the standoff length by 2, with the plate thickness they won't hit each other.
Edit: and if you aren't counter sinking the plates you'll want button head or similar
« Last Edit: Wed, 17 February 2016, 14:15:44 by Joey Quinn »
Offline axtran
« Reply #527 on: Wed, 17 February 2016, 14:17:23 »
Countersunk screws look better :thumb:
« Reply #528 on: Wed, 17 February 2016, 14:18:25 »
Yes but if the plate isn't counter sunk they'll sit very weirdly and won't tighten correctly. It'll look like ****.
Offline axtran
« Reply #529 on: Wed, 17 February 2016, 14:20:09 »
Definitely true. But hwood34 hasn't shown us the beauty yet! ;)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #530 on: Wed, 17 February 2016, 14:42:59 »
these?
So something like this
Offline axtran
« Reply #531 on: Wed, 17 February 2016, 14:54:15 »
What do you think about socket cap with Torx?
« Reply #532 on: Wed, 17 February 2016, 15:22:18 »
Yeah, a binder head will work fine and the length will be perfect.
That'll be taller than a binder or button head and most people might not have torx but I suppose it's up to the people in the GB.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #533 on: Wed, 17 February 2016, 15:43:18 »
I don't suppose anyone is interested in 200 of 3/4" binding posts?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #534 on: Wed, 17 February 2016, 19:32:20 »
Spacers and screws ordered, should be here around the 22nd
Offline axtran
« Reply #535 on: Wed, 17 February 2016, 20:06:23 »
Super excited!
Offline radio_killah
  • Chinchillin'
« Reply #536 on: Wed, 17 February 2016, 20:08:51 »
Offline Ngt
« Reply #537 on: Thu, 18 February 2016, 04:06:23 »
Alright thanks for handling the little crisis! I guess you paid with your own funds, didn't you? Do you need to split the amount? I'm not really in a good financial situation atm but I can help I'm sure!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #538 on: Thu, 18 February 2016, 09:34:56 »
It's fine, wouldn't want to put you in a worse position
Offline Ngt
« Reply #539 on: Thu, 18 February 2016, 17:42:37 »
Well I can't give you $50 but I can ship in $10 like the last time if that helps. I know that you are not rolling in money either as you are a student and this project took in your pockets. :/
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #540 on: Mon, 22 February 2016, 15:05:51 »
Got the spacers and screws today. Everything is fine, except the spacers a teensy bit too wide. Luckily, since they're nylon you can just sand them a tiny bit and they fit nicely. I'll send out the first six sets to people to make sure everything is in order
Offline heedpantsnow
  • Old enough to know better
« Reply #541 on: Mon, 22 February 2016, 15:44:07 »
Cool, great news!
I'm back.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #542 on: Mon, 22 February 2016, 16:28:29 »
And here are some quick shots of the full cases. I'll work to get some prettier shots once I get the second round of cases
Offline Vimto
« Reply #543 on: Mon, 22 February 2016, 16:53:53 »
They look amazing
Offline axtran
« Reply #544 on: Mon, 22 February 2016, 17:34:59 »
HOLY MOLY! Looks awesome!
Offline user 18
« Reply #545 on: Mon, 22 February 2016, 17:49:29 »
Beautiful. Has it been confirmed that everything fits properly now?
Avatar by ashdenej
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #546 on: Mon, 22 February 2016, 17:51:14 »
Yup :thumb:
Offline axtran
« Reply #547 on: Mon, 22 February 2016, 18:09:29 »
Ooh mass production! (or as quick as one man can do it... lol)
Offline Ngt
« Reply #548 on: Tue, 23 February 2016, 04:49:05 »
Oh yeah baby! As pretty as I was expecting it to be! When you'll have the time for the prettier shots, do you mind taking some profile pictures with the middle piece as well please? So far it seems to give pretty much the same look as if it was a frosty polycarb middle piece IMO which is awesome! :D
Did they give you an ETA for the second round of cases btw?
Thanks again Hwood!
P.S: I wonder how much does it weigh as well.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #549 on: Tue, 23 February 2016, 19:42:06 »
Thanks again Hwood!
Yeah, the waterjetting seems to have given it sort of a frosted look. I'm just waiting til the first set of people get their cases and confirm that everything is perfect before making the last batch.
And I totally forgot to weigh, guess either someone here can do it or I will if no one does by the time I get the next cases
