Author Topic: make your fukkas even smoother  (Read 73841 times)
Offline wellington1869
« on: Mon, 14 September 2009, 23:41:31 »
So I managed to make my fukkas even smoother and even quieter. They're just brilliant, I love it.
I put a spot of grease where the sliders make contact with the click leaf's prongs. See pic below.
Its like butter. Seriously. Made a fantastic typing experience even better.
Basically it "smoothed out" the downstroke on the already quite smooth fukkas. The main resistance on the clicky fukka is the click leaf's prongs when you begin your downstroke. They give just a little and then slide off the slider (causing the hammer to strike the casing, making the click noise).
When you grese that spot, basically the leaf slides off the hammer just slightly quicker and smoother. The click is also just slightly reduced presumably cuz its not pulled down as much before snapping back (because of the grease). The effect is very subtle - there is still a click and there is still the resistance of the prongs. The point is, they're smoothed out a touch. Its noticeable without messing with the overall resistance and feel of the key. For instance I did the rip test and key resistance was 60g before and it was 60g after the tweak.
The result is a key that flies and feels smooth and substantial like no other switch except the bs. I often compare the fukka to bs both in terms of satisfaction but also in terms of feel. The fukka is a lighter bs (by about 5g) which actuates slightly earlier on the downstroke, but otherwise they're quite similar for medium-to-heavy switches which are very satisfying to type on.
« Last Edit: Tue, 15 September 2009, 18:31:03 by wellington1869 »
using: ms 7000/Das 3
Offline itlnstln
« Reply #1 on: Tue, 15 September 2009, 08:01:20 »
Thread abortion?  That's what happens when you have too much sex with your keyboards, Welly.  You really need to use protection, or, better yet, practice abstinence.
Offline ch_123
« Reply #2 on: Tue, 15 September 2009, 09:11:33 »
Funny enough, I was thinking the same thing when I saw the title. Got in too late I guess :P
Offline rdjack21
« Reply #3 on: Tue, 15 September 2009, 09:26:25 »
Be a man and live up to your responsibilities. Don't kill the poor innocent thread. Give it a little love and help it grow instead.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
« Reply #4 on: Tue, 15 September 2009, 11:12:55 »
oh no, abortion attempt turning into botched abortion! ;)
hmmm, lets see, maybe there's something in my room I can 'review' here.  ;)
Offline rdjack21
« Reply #5 on: Tue, 15 September 2009, 12:07:35 »
Quick go buy something.... Actually as much as you like Alps you should get a SIIG or one of those Filco SIIG look a likes. You need a mini Alps board.
Keyboards
Black Alps: ABS M1
« Reply #6 on: Tue, 15 September 2009, 12:56:15 »
maybe my topre will give birth to a filco.  I dont think I used a condom. ;)
« Reply #7 on: Tue, 15 September 2009, 12:59:22 »
Quote from: rdjack21;118118
oh, you're evil.  ;)
Offline itlnstln
« Reply #8 on: Tue, 15 September 2009, 13:04:01 »
Quote from: wellington1869;118130
I feel sorry for who you sold that to.
« Reply #9 on: Tue, 15 September 2009, 13:13:28 »
Quote from: itlnstln;118133
hahaha hey at least this girl is honest about where she's been. All our ebay boards are hoes too, masquerading as virgins.
« Reply #10 on: Tue, 15 September 2009, 18:21:09 »
Ok, here, I'll use this space. Here's a mod to make your fukka's even better. ;)
« Last Edit: Tue, 15 September 2009, 18:29:48 by wellington1869 »
