Author Topic: Panasonic KX-W900 in Devon, England  (Read 3177 times)
Offline ed_avis
« on: Sun, 03 May 2015, 14:41:20 »
www.gumtree.com/p/desktop-workstation-pcs/panasonic-kx-w900-word-processor-c-w-instruction-manual/1114327015
I don't know what kind of keyswitches Panasonic typewriters used.  Local pickup from Newton Abbot.
Offline jacobolus
Re: Panasonic KX-W900 in Devon, England
« Reply #1 on: Tue, 05 May 2015, 03:08:24 »
Pretty sure this one is some type of terrible rubber dome. Some (especially earlier) models of Panasonic typewriters used Alps switches.
Offline ed_avis
« Reply #2 on: Tue, 05 May 2015, 04:58:46 »
That's a shame.  And I guess there aren't any Panasonic Toughbook laptops with decent keyboards either?
Offline ander
  • I type, therefore I am
« Reply #3 on: Tue, 05 May 2015, 16:26:38 »
Pretty sure this one is some type of terrible rubber dome...
But at the very least you could pick it up personally, and then you'd get a trip to the UK out of it... Not bad!
« Reply #4 on: Tue, 05 May 2015, 17:32:48 »
Whoa. The industrial design of it... It looks like a video cassette player from the '80s with a keyboard. :)
« Reply #5 on: Thu, 07 May 2015, 09:33:36 »
I actually stumbled upon a sibling to this typewriter in a thrift store today. Not the exact model, but very close.
I pulled a key and checked. It has a coiled spring over membrane. The slider is integrated into the keycap, so not compatible with any mechanical switches that I know of.
The key action is linear and light with short throw. Creaky on off-centre key presses.
Nice texture on the keys though: gritty without being coarse.
