Author Topic: LED on MX / Topre Switches Question...  (Read 2014 times)
Offline whizzard
  • whizzard got ur gizzard
    • LOOTKEYS BLOG
« on: Mon, 04 May 2015, 14:26:51 »
Hey just a quick question.  I am making artisans and have found a way to make translucent eyes / mouth on the face of the key.  Are the LED hole positions on switches always at the bottom of the switch?  Mine are, but not sure if all are.  Because of this I was thinking of only making the mouth (bottom part) translucent.. because when I do both eyes and mouth only the bottom mouth part is well lit.  Do any switches have the LED positioned at the top of the switch (meaning where the eyes would be).
Offline trizkut
Re: LED on MX / Topre Switches Question...
« Reply #1 on: Mon, 04 May 2015, 14:29:09 »
It depends on the orientation made available by the PCB.  Some orient the switches with the LED hole on top, others with the LEDs on the bottom.
Offline whizzard
    • LOOTKEYS BLOG
« Reply #2 on: Mon, 04 May 2015, 14:29:43 »
Thanks... that makes sense.  And that goes for MX and Topre?
Offline trizkut
« Reply #3 on: Mon, 04 May 2015, 14:48:00 »
The only LEDed 'topre' I can think of is the royal kludge, which I believe has leds in the top left corner:
