Author Topic: Cherry MX 8100 G80-8963LUBUS-2 MX Browns USB - $35 BIN  (Read 2178 times)
Offline tuan2195
« on: Tue, 05 May 2015, 01:10:34 »
http://www.ebay.com/itm/Cherry-MX-8100-G80-8963LUBUS-2-Mechanical-Keyboard-2001-lw-N-I-Use-for-Gaming-/381249133902?pt=LH_DefaultDomain_0&hash=item58c4381d4e
Good for someone looking to try out MX Browns or want to harvest some switches or otherwise just want to spend their money on vintage board. I almost bought it myself but then I realized it's MX Brown which I don't really like.
Offline ander
  • I type, therefore I am
Re: Cherry MX 8100 G80-8963LUBUS-2 MX Browns USB - $35 BIN
« Reply #1 on: Tue, 05 May 2015, 16:29:59 »
Wow, that is cheap, esp. if it's in decent shape. Dig all the relegendable keys.
Ah, it's a POS board—there's a card-swiper at the top. That explains the caps. Does that mean it wouldn't be usable with a PC? Or just that you'd need a driver to use the swiper?
Offline njbair
    • nickbair.net
« Reply #2 on: Tue, 05 May 2015, 22:40:56 »
The swiper just "types" the credit card data for you. AFAIK all swipers follow a standard format: http://en.wikipedia.org/wiki/Magnetic_stripe_card#Financial_cards
My boards:
