Author Topic: autohotkey problems (an ongoing thread with older problems bumped down the OP)  (Read 2479 times)
Offline berserkfan
New problem with my autohotkey
(The older problem, which has been solved, has been bumped down the OP)
I am trying to do 2 things on the same autohotkeyscript.
1)   rearrange the alphas to my custom layout
2)   put in some key combos tied to my custom layout
For instance, I want to turn the original B (scancode 030) to K.
The original N to B
The original J to N
And then put in macros such that when I press windows-b, I get the BBC. When I press windows-n, I get the New York Times.
Here’s some sample script that doesn’t work. I can get the New York Times, but not the BBC. The funny thing is, the exact same script worked when I was still using standard layout ie did no try rearranging the alphas. But once I added in the code rearranging the alphas, I got problems.
j::n
sc030::k
n::b
#n::
Run http://www.nytimes.com/
return
#b::
Run http://www.bbc.co.uk/news/
return
Just for reference, the entire block of code added is this. It's my custom modified colemak layout.
w::g
e::f
r::  p (space added to avoid an auto smiley forming)
t::w
y::del
u::l
i::u
o::j
sc019::y
]::backspace
capslock::backspace
a::r
s::a
d::s
f::t
g::d
j::n
k::e
l::i
sc027::  o (space added to avoid an auto smiley forming)
c::v
v::c
sc030::k
n::b
OP below kept for archive purposes
I haven’t posted about this for a while because I’d gotten most of my ahk problems under control. But now I have to ask… any input would be deeply appreciated!
I want to use the numpad3 as a ‘multi pagedown’ instead of single page down and numpad9 as a multi page up.
I created this code
NumpadPgUp::
Loop, 4
Send 4{PgUp}
Return
NumpadPgDn::
Loop, 4
Send 4{PgDn}
Return
This code works fine when in a pdf document or google chrome. Unfortunately, when trying to page up and down quickly in a word document, pressing num3 will lead to the number 4 being inserted 4 times, once on each page down. Ditto for num9, which inserts 4 for each page up.
Does anyone have a suggestion on how I can solve this?
« Last Edit: Tue, 05 May 2015, 20:32:11 by berserkfan »
Offline trizkut
Re: autohotkey problem
« Reply #1 on: Tue, 05 May 2015, 10:38:21 »
Is there a reason why you have 4 before {PgUp} and {PgDown}?  I'd guess that's why you're inserting 4s
Offline berserkfan
« Reply #2 on: Tue, 05 May 2015, 10:42:42 »
I want to do 4 page ups or downs at the same time. That helps me move more quickly through a long document, since I can already do one page up/down with the regular page up/down key.
Offline trizkut
« Reply #3 on: Tue, 05 May 2015, 10:43:08 »
Isn't that what the loop is for?
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #4 on: Tue, 05 May 2015, 10:44:29 »
I don't understand why they are their either, but I would *imagine* it would send 4 4's if that were the issue.
Maybe you need to add a quarter-second or so wait time?
Offline trizkut
« Reply #5 on: Tue, 05 May 2015, 10:55:15 »
He said it did, once for every PageUp/PageDown.  It doesn't affect pdfs/chrome because you aren't editing in those instances.
Offline greath
« Reply #6 on: Tue, 05 May 2015, 11:09:26 »
My fault. I misread the original. I thought he was only getting the number 4 once on the word documents. That's what I Was saying was strange.
Offline berserkfan
« Reply #7 on: Tue, 05 May 2015, 11:42:18 »
OK, I corrected my code based on the feedback received.
NumpadPgUp::
Loop, 4
Send {PgUp}
Return
NumpadPgDn::
Loop, 4
Send {PgDn}
Return
works now. Thanks everyone!
