Author Topic: HHKB Type-S Slider color?!?!  (Read 4681 times)
Offline IonutZ
  • Stay awhile and listen
    • SC
« on: Wed, 06 May 2015, 08:35:17 »
Hey guys,
I bought an HHKB Type-S off a dude on Reddit and it came with Black sliders. Aren't they supposed to be Purple??
I'm gonna have to open it up and see if it's not dental band modded instead (although it doesn't feel like it)... But my 2 @ key clicks in a weird way when it bottoms out, like it's in 2 stages...
Offline Khers
  • Schrödinger's box
Re: HHKB Type-S Slider color?!?!
« Reply #1 on: Wed, 06 May 2015, 08:37:24 »
« Last Edit: Tue, 03 July 2018, 08:18:28 by Khers »
« Reply #2 on: Wed, 06 May 2015, 08:37:34 »
They are always black. Only the Realforce comes with purple sliders.
Offline IonutZ
    • SC
« Reply #3 on: Wed, 06 May 2015, 08:41:00 »
Ok, well that puts one of my worries aside, thank you for that! Also compared to a regular slider (since we're on the topic), are they taller? I would guess so because dental banding a regular HHKB takes away from the bottoming out distance.
Offline FrostyToast
  • Litshoard
« Reply #4 on: Wed, 06 May 2015, 09:08:24 »
The base is thinner thus compensating for the added thickness from the rubber rings.
Quote from: elton5354
Offline IonutZ
    • SC
« Reply #5 on: Wed, 06 May 2015, 09:19:28 »
Can you achieve the same thing from filing down some of the base?
Offline btctopre
« Reply #6 on: Wed, 06 May 2015, 09:29:52 »
You'd probably have consistency issues, but I don't see why not. And the silent sliders (at least the purple ones) are indeed a hair taller than the non Type-S sliders.
Offline Herothereu
« Reply #7 on: Wed, 06 May 2015, 10:19:24 »
My Novatouch has purple sliders.
Offline IonutZ
    • SC
« Reply #8 on: Wed, 06 May 2015, 10:24:55 »
It's gonna rain tomorrow...
« Reply #9 on: Wed, 06 May 2015, 10:28:08 »
Your dome/spring could be just a little off in the 2 keys that click.
Offline IonutZ
    • SC
« Reply #10 on: Wed, 06 May 2015, 10:33:48 »
Yea I'm gonna open it up tonight and see what's up... or maybe in a few days when I get the topre shipment from japan :x
Goal is to make my new black HHKB into a 55g Type-S
« Reply #11 on: Wed, 06 May 2015, 10:36:07 »
I've always wanted to do that. :D
« Reply #12 on: Wed, 06 May 2015, 10:38:13 »
Yes they're taller hence why I like dental banding better.
Offline IonutZ
    • SC
« Reply #13 on: Wed, 06 May 2015, 10:44:19 »
For about 30s (before I sold my dental banded HHKB), I got to test the Type-S with my old HHKB side by side... to be honest, ever since I had dental banded it, the bottom out feeling was completely different. I much prefer the travel of the Type-S (although I think the dental banded HHKB was more silent)...
