Author Topic: QuickFire TK Blue  (Read 18300 times)
Offline ManxLOLcat
QuickFire TK Blue
« on: Wed, 06 May 2015, 09:56:02 »
Hey guys, pretty new when it comes to spray painting things but I decided to give it a try, so I'm here to show my results for my QF TK!
With the QF TK there are some problems with key sizes so that's why some of the keys are still default, plus I didn't have enough white caps.
The paint job is pretty poor but not terrible, however I don't thinks it's too noticeable in the pictures. I also painted the space bar but again, pretty bad painting. This was my first time spray painting anything so I think it went pretty well. Main reason the painting was bad is because I used the wrong sandpaper. I thought that any should do but I realised my mistake.
White PBT keycaps and some leftover ALT keys from my brother's poker.
Feel free to give me some feedback so I can do a better job next time!
Re: QuickFire TK Blue
« Reply #1 on: Wed, 06 May 2015, 15:11:34 »
Apart from a small flaw in the lower right corner of the case, and the different profile keycap on the number pad, looks pretty good :)
