Author Topic: CMStorm Trigger repair  (Read 2272 times)
Offline cycloptishred
« on: Wed, 06 May 2015, 17:59:33 »
A few days ago my keyboard suddenly started giving scrambled inputs so I took it apart (using information I found on this website) and I found this corrosion on the PCB. You guys think it's fixable?
Offline berserkfan
Re: CMStorm Trigger repair
« Reply #1 on: Thu, 07 May 2015, 08:51:22 »
Wash with isopropyl alcohol, use an acid brush (or whatever they call these things). If you don't have one, then use a toothbrush WITH SOFT BRISTLES.
 When the board is clean, we can see the traces better. Probably it is just the muck causing the keyboard to be shorted out.
« Reply #2 on: Thu, 07 May 2015, 19:57:49 »
Thanks for the reply! What exactly do you mean by "wash"? Any scrubbing involved?
