Author Topic: HHKB weird spacebar sound  (Read 2721 times)
Offline s0nia
« on: Wed, 06 May 2015, 23:30:09 »
My new HHKB's spacebar makes a rattle/squeak when I hit it on the right side... Does anybody know what this is and how I could fix it? Thanks
« Last Edit: Fri, 08 May 2015, 13:30:00 by s0nia »
Offline byker
  • Literally Canada
Re: HHKB weird spacebar sound
« Reply #1 on: Wed, 06 May 2015, 23:38:04 »
Not sure what that is. Did you try removing the spacebar and putting it back on? If you are unsure you could maybe take some pictures of it with the nearby caps removed so we can take a look!
Offline lookitdisnub
« Reply #2 on: Thu, 07 May 2015, 01:14:29 »
I believe it's the stabilizer that causes it. Not sure how to get rid of it, but I think over time it goes away on its own
Offline s0nia
« Reply #3 on: Thu, 07 May 2015, 16:13:01 »
The sound is kind of squeaky. How do you recommend I go about removing the caps without a puller? Thanks!
Offline illitirit
« Reply #4 on: Thu, 07 May 2015, 20:03:30 »
lol wierd I never noticed mine has a noise when I tap the right side only.'
However, mine is not a squeak its more like a....  plastic tap noise.
The left side does not do it.  Doesnt bother me much since it doesnt happen in regular typing.
Offline byker
  • Literally Canada
« Reply #5 on: Fri, 08 May 2015, 00:12:10 »
Check this out for a few different ways: [size=78%]https://www.reddit.com/r/MechanicalKeyboards/comments/15lk5m/how_to_remove_a_key_cap_without_a_key_cap_remover/[/size]
« Reply #6 on: Fri, 08 May 2015, 02:56:14 »
Glorious hhkb is perfect. It's your ears that don't work.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #7 on: Fri, 08 May 2015, 02:57:46 »
That custom title really needs to be changed....  :))
Offline s0nia
« Reply #8 on: Fri, 08 May 2015, 13:06:30 »
Here's a video of the issue:
Please excuse the background noise!
