Author Topic: How to remove and or repair the trackpoint on a M13 Model M buckling spring?  (Read 1926 times)
Offline berserkfan
I have an M13 Model M that came with a broken trackpoint. it is not just non-working; it is physically broken and has come loose from the keyboard (but is still connected by some wire).
Since I don't like the trackpoint function anyway, I would like to remove it entirely. I am not planning on taking apart the entire keyboard, so would prefer to just disengage that trackpoint somehow so that I can put in a regular set of Model M keycaps and not accidentally have to touch that filthy old trackpoint tip.
ALTERNATIVELY
I could repair the trackpoint and sell the keyboard. If anyone can give me ideas it will be very appreciated.
Offline E TwentyNine
    • Some of My Keyboards
Is the stick broken off from the base or is the whole base off the barrel frame?
The wire just leads to a second controller board that you can unplug it from if the whole base is already broken off.
« Last Edit: Thu, 07 May 2015, 09:38:01 by E TwentyNine »
