Author Topic: My QFR Endeavours  (Read 2812 times)
Offline Bludude4
My QFR Endeavours
« on: Thu, 07 May 2015, 13:10:25 »
June 8th, 2014 was when I got my first, (and so far, last) mechanical keyboard. I've put it through a lot of crap. In the first few months, the board had its first defect. The F9 switch sort of became linear, and lost its click. Everything else was working fine, until I got tired of the board wobbling when it the feet were elevated (which is my preferred position). So I made some minor modifications to bottom of the board, and it was fixed. The other day, I spilled about 50mL of soda on the board. I immediately took the board apart, wiped down the plate, the inside and outside of the case, and the PCB (which wasn't easy because of the soldering connections). A day or two later, the S key began to have the same problem as the F9 key. It wasn't clicking anymore, and there was no tactile bump.  It was also gummy. So what did I do? I did the worst thing anyone could ever think to do. I got an eyedropper and put a few drops of WATER into the SWITCH. After wiping the switch with tissue paper and plugging the board back in, the S key wasn't gummed up anymore, but still linear. The problem was, it wasn't actuating at all. That was when I realized what I had done. I had put WATER in the switch. My next thought was "put isopropyl alcohol in there." So I did. It dried up the inside of the switch, and the S key actuated again. My keyboard is functional, with the linear problem in F9, S, and as I was typing this, I figured out X, as well. All keys actuate, and that's about it.
All hail Hall Effect keyboards!
I'm a QFR Blues noob.
WASD keycaps are terrible.
Offline Axollott
Re: My QFR Endeavours
« Reply #1 on: Thu, 07 May 2015, 13:56:32 »
Don´t ever treat a person how you've been treating that keyboard.
And don´t ever touch anybody´s concert piano. Please.  :p  :cool:
Offline Snarfangel
« Reply #2 on: Thu, 07 May 2015, 14:01:53 »
Don't ever treat a person how you've been treating that keyboard.
And don't ever touch anybody's concert piano. Please.  :p  :cool:
Middle C on my piano was sticking, so I used WD-40. Then it was too slippery, so I put some gymnast's chalk on it. Which of course made me sneeze.
So I was wondering...  any suggestions to cure sneezing?
Offline Bludude4
« Reply #3 on: Thu, 07 May 2015, 14:22:23 »
Don�t ever treat a person how you've been treating that keyboard.
And don�t ever touch anybody�s concert piano. Please.  :p  :cool:
Yeah, I'm really hard on  *my* things. I don't know how the F9 switch failed, though.
That made me laugh so hard. XD
Offline Axollott
« Reply #4 on: Fri, 08 May 2015, 04:28:59 »
And don't ever touch anybody's concert piano. Please.    :cool:
Hahaha
« Reply #5 on: Sun, 10 May 2015, 05:01:35 »
Blues or greens?
A tactile switch cannot become linear through normal use, and not even as a result of immersion in liquid, at least not sufficient liquid to probably melt most of the switch.
Blues/greens can lose their click if the slider becomes gummed up even a tiny bit.  In those situations you an try mashing the key.  I have a keyboard where up arrow and X lost their click, but otherwise were well-behaved MX blues.  I totally mashed the up arrow as much as I could, thousands of extra presses, and eventually it clicks more or less normally.
I have not found an excuse to mash X as much, but it sometimes clicks.
But throughout all switches were still tactile.
Offline Bludude4
« Reply #6 on: Sun, 10 May 2015, 23:07:35 »
Blues or greens?
Blues. My s key has fully recovered somehow, but my F9 key is still linear.
« Reply #7 on: Mon, 11 May 2015, 05:51:18 »
Blues or greens?
Weird - a tactile switch cannot become linear - the tactility is what makes the contacts touch.
« Reply #8 on: Mon, 11 May 2015, 07:04:18 »
Have you tried that the F9 works, I.e. that something happens on the computer when you press it?
