Author Topic: hi im new  (Read 1994 times)
Offline condoriano
hi im new
« on: Sat, 09 May 2015, 00:50:31 »
My keyboard just broke. It was a crappy old 10$ rubber dome piece of junk that won't be missed. Now i want something badass and fully programmable to replace it, with a layout like a 75% or 60% with extra top row and blue mx switches similar to https://geekhack.org/index.php?topic=65036.0 so it led me here where hopefully i can learn things in order to obtain my dream keyboard
Offline Rotaku
  • Too Based
Re: hi im new
« Reply #1 on: Sat, 09 May 2015, 00:55:26 »
Welcome to the community :D Have you thought about the Race 2 or Noppoo Choc mini?
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Offline condoriano
Re: hi im new
« Reply #2 on: Sat, 09 May 2015, 01:40:22 »
thank you! the physical layouts of those are what i am searching for, but i also search for something that allows customizable firmware that can hold different dynamically switchable layouts. that doesnt seem to be the case since they don't specify the use of a controller like teensy that you can reprogram with the usb interface, so im assuming its not the case. but i could be wrong  :))
Offline condoriano
Re: hi im new
« Reply #3 on: Sat, 09 May 2015, 02:16:57 »
ive been wondering if there are commercial keyboard that allow custom firmware loading. Or else i would rather make my own than buy a brand new keyboard and put a microcontroller inside it.
Offline bazh
Re: hi im new
« Reply #4 on: Sat, 09 May 2015, 03:34:59 »
Hi new!
HHKB Pro2 white
Newbie again
Offline trizkut
Re: hi im new
« Reply #5 on: Sat, 09 May 2015, 05:27:55 »
Commercial, probably not.  If you're okay with soldering, there's always the B.Mini:
http://winkeyless.kr/product/b-mini-pcb/
http://winkeyless.kr/product/b-minir-pcb/
Their bootmapper is relatively easy to use for programming keys:
https://geekhack.org/index.php?topic=58945.msg1348915#post_SW
This is for the faceW pcb, but the winkeyless boards use the same bootmapper.
Offline condoriano
Re: hi im new
« Reply #6 on: Sat, 09 May 2015, 16:14:29 »
that seems like what im searching for; i have no problem with soldering and assembling the parts. I sent an email to the owner about a schematic of his PCBs, since it doesnt seem to be anywhere on his website. Since basically when buying a custom keyboard it seems you are buying mainly the pcb and the metal plates. The rest is some generic stuff you can get on your own. So i need to make sure the PCB circuit is what i want.
Re: hi im new
« Reply #7 on: Tue, 12 May 2015, 06:01:27 »
Welcome to Geekhack!
Good luck on your search!  Although the GB has finished, you might still find someone that wants to sell theirs.
Offline LXXXIX
  • Just remember all caps when you spell the man name
Re: hi im new
« Reply #8 on: Tue, 12 May 2015, 07:29:12 »
Welcome to GH! It seems like you want to go all in (which is a good thing).
Good luck finding what you want on here. There's a wealth of information on here of exactly what your looking for.
We're glad to have you here and if you have any questions feel free to get in contact with anyone on here. Don't be afraid to start a discussion either. :thumb:
