Author Topic: MS Natural Pro dishwashing results  (Read 2321 times)
Offline lowpoly
« on: Wed, 16 September 2009, 08:22:54 »
So I dishwashed my MS Natural Pro which I got as an add-on to the M2 I bought lately (seller thought the M2 was the add-on) and everything came out just fine. At least until I had this mess of parts back together. When I tried it, it worked but I have to hit the keys dead center or they will block.
I only tried it for literally 3 seconds before. It worked fine then, I guess?
I think the dishwasher may have washed away the lubricant.
Anybody have that keyboard? Do you have to hit the keys in the center?
Offline lowpoly
« Reply #1 on: Wed, 16 September 2009, 11:07:04 »
Maybe it was the lubrication as well. The grease they use might be water-soluble.
Offline patrickgeekhack
« Reply #2 on: Fri, 18 September 2009, 10:06:31 »
This is why I'm so scared of putting any of my keyboard in a dishwasher.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline lowpoly
« Reply #3 on: Fri, 18 September 2009, 10:53:45 »
Quote from: patrickgeekhack;119002
With mechanical switches it is usually not a problem as they do not go into the dishwasher. But while dishwashing results were great in the beginning, problems are piling up lately.
Quote from: ripster;119007
Actually I kinda doubt this is the problem.  The sliders on these cheapo boards are so loose fitting they don't appear to grease the Logitechs at all so even if they warped a bit they should be OK.
Don't think something got warped. The (bad) effect is kind of consistent.
Offline lowpoly
« Reply #4 on: Fri, 18 September 2009, 10:55:02 »
With mechanical switches it is usually not a problem as they do not go into the dishwasher. But while dishwashing results were great in the beginning for me, problems are piling up lately.
I don't think something got warped. The (bad) effect is kind of consistent. Keys work fine when pressed in the center but blocking closer to the edges.
The keyboard is shelved in a distant corner for now.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #5 on: Sat, 19 September 2009, 09:38:52 »
I never thought about putting keyboards in the dishwasher. Now that I think about it. I'm kind of glad I didn't.
