Author Topic: "StarWave" aluminium case project  (Read 4039 times)
Offline NUDEcnc
    • My YouTube channel
« on: Sun, 10 May 2015, 10:39:51 »
Hi guys!
     Some time ago I came up with an idea of the new keyboard case project.  My goal was to make a 4-key keyboard, with a display screen on the top of the case.
This will be my third keyboard and as 2 previous ones this one will be based on techkeys.us PCB
you can find this PCB here:
http://techkeys.us/collections/accessories/products/techkeys-programmable-keyboard-business-card
I decided to name to project “StarWave”.
The case will be made from aluminium, will have 2 brass legs on both sides, and carbon fibre+brass back plate.
         As techkeys PCB has 7x24 LEDs screen I needed to find way to “project“ led light beam on the top of  the case.
Initial solution for that is to use fibre optics.
       As an extra feature I plan to cover the case with pure silver (or chrome)
So far I have made a prototype, which turned out quite nicely...but I had few problems.
1 custom animation on the screen
2 main case finish – options: uncoated aluminium, anodised chrome or silver coating
3 shape of backplate brass part – ?
4 diameter of the reset button hole-paper clip size?
This is 1st build video of machining the back plate.
Custom CNC machined 3D mechanical keyboard VIDEO
I will be more than happy to hear your feedback whether you like the project, or not, and suggestions how to improve this design.
« Last Edit: Wed, 13 May 2015, 02:31:40 by NUDEcnc »
Re: "StarWave" aluminium case project
« Reply #1 on: Sun, 10 May 2015, 10:47:39 »
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #2 on: Sun, 10 May 2015, 11:19:36 »
This is awesome. I want one!
Offline Charger
« Reply #3 on: Sun, 10 May 2015, 12:40:35 »
it looks so useless but I love it lol
I already saw the bottom plate machining on youtube lol
Offline NUDEcnc
« Reply #4 on: Wed, 13 May 2015, 02:40:10 »
Well I'm not much of programmer, but I do believe this card can do few cool things :)
I did add link in top post.
THX
